painting under the car, what are you using |
sanman |
Feb 3 2005, 03:00 PM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
Hi all. I Have my car on jack stand and would like to paint the under side and fender wells. I would like to Know who has done this. This car will never see rain But I want it to look Good. What I have in mind is
a. bed liner b. rustolium c. ruberized undercoat there is curently NO rust under the car but it is rough underneth look like some places original paint some places some type of textured undercoat ps I know por 15 would be best but is'nt it expencive and time consuming to apply. any pic |
TonyAKAVW |
Feb 3 2005, 03:19 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I bet you could paint the underside of your car with $50 to $60 worth of POR-15. Bedliner unless you get the do-it-yourself kind will probably be a lot more expensive than that. Rubberized undercoating is probably worse than nothing at all, as it traps moisture against the paint. do-it-yourself bedliner is probably about the same, maybe just a bit more durable.
Rustolium might work too, but keep an eye on it over time. (as with anything) POR-15 is probably your best bet aside from original paint. -Tony |
Allan |
Feb 3 2005, 03:21 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Here is a place I got some POR-15 from. You might check out their prices. They will tell you how much it will cover.
POR-15 |
vortrex |
Feb 3 2005, 03:26 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
there is a product called Zero-Rust that is much easier to work with than POR-15 and looks better too.
scotty b |
Feb 3 2005, 03:27 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
bed liner is more expensive than Por 15 but will give the best resuls as far as rust prevention.HOWEVER you really should clean and paint with POR before putting on bedliner,otherwise you will be covering rust with bedliner and not doing any good. Rustoleum and undercoating do not mix well. I applied that combo giving the rustoleum DAYS to dry, and when applying the undercoat, it ate the rustoleum and neither would adhere.
94teener |
Feb 3 2005, 03:39 PM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
I second the Zero Rust. I have been using it for years and never had to recoat.
The underside of all of the 914s I have are painted with ZR. Phil |
xsboost90 |
Feb 3 2005, 03:43 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
what ever you put on you should clean what is on there off or it wont stick. Ive used a bunch of rock chip guard in some spots ive fixed and then put undercoating over that. I also por 15'd some spots and painted over it and undercoat in spots.
sj914 |
Feb 3 2005, 06:43 PM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Por15 makes a hardnose paint that they claim is tough and cleans good.
Sparky |
Feb 3 2005, 06:48 PM
Mahna Mahna! Group: Members Posts: 1,134 Joined: 21-June 03 From: Spencer, MA Member No.: 847 |
I've used Rust Bullet with great results. IIRC it was a little less expensive then POR15 and the specs were just as good.
My best, Mike D. ...There I contributed something useful today! |
LvSteveH |
Feb 3 2005, 09:17 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
I second the RustBullet, it's not cheap, but applies much easier than POR 15, and it saves you money, you don't have to buy beer, you'll have a nice buzz after painting with it. Oh, take serious precautions to prevent getting on your skin, it will not come off. I got some on my face (don't ask) and had to use a scotchbright pad to remove the skin the paint was attached to. Talk about exfoliating!
guywan914 |
Feb 4 2005, 04:03 PM
Member Group: Members Posts: 221 Joined: 27-May 04 From: Columbia,CT Member No.: 2,112 |
Where would one find info on zero rust? Do you by it direct like por-15. My teener is just about clean to the metal on the bottom waiting for the por 15 but open to suggestions.
94teener |
Feb 4 2005, 04:21 PM
jwalters |
Feb 4 2005, 08:16 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) A tyvek suit....... (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Trust me--you want to use one of those when you do it......
Lo-Fi Version | Time is now: 31st May 2024 - 07:29 PM |
