Window fuzzy strip installation |
Harpo |
Dec 31 2014, 03:31 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Harpo |
Dec 31 2014, 03:43 PM
stevegm |
Dec 31 2014, 03:54 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Not to hijack your thread. But I was just getting ready to post a question - how do you get the channel off with the windows in? I know there are three screws holding the channel on. But it doesn't appear that you can get access to them with the windows in. I searched the forum, to no avail. Anyone know?
Harpo |
Dec 31 2014, 04:22 PM
I removed my window before removing those screws
David |
stevegm |
Dec 31 2014, 04:24 PM
Harpo |
Dec 31 2014, 04:29 PM
That is what I'm up to as well. I'm currently stuck on the forward (aluminum) window channel.
David |
stevegm |
Dec 31 2014, 05:18 PM
That is what I'm up to as well. I'm currently stuck on the forward (aluminum) window channel. David Forward channel? Do you mean the front of it? Are the new fuzzy strips OEM, or repos? Possibly a slightly different size? Question - it seems like most of the aluminum channels that hold all of the rubber are glued on with a black glue that makes it very difficult to get them off without bending them. Were yours glued on? When you put the channels back on does everybody reglue them? Or just screw them on? Thanks, Steve |
OU8AVW |
Dec 31 2014, 06:14 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
Your aluminum looks bent. I just did this to my '71 with the 914rubber parts. I had no problem making it all stay together. Be careful to line up the holes in the fuzzies with the holes in the aluminum.
PanelBilly |
Dec 31 2014, 06:53 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I had to use some pliers to squeeze the channel closed.
Harpo |
Dec 31 2014, 07:17 PM
These are 914rubber fuzzies. The old/original ones were a tight fit. I will check with Mickey
EdwardBlume |
Dec 31 2014, 07:22 PM
Taking the aluminum piece off can be a bear. I drilled mine out. Make sure its on good otherwise you'll be taking it all apart a 2nd time.
Harpo |
Dec 31 2014, 07:29 PM
I had to drill mine out also. I used a reverse twist drill bit with the drill in reverse
David |
EdwardBlume |
Dec 31 2014, 07:41 PM
I had to drill mine out also. I used a reverse twist drill bit with the drill in reverse David Nothing wrong with braggin' (IMG:style_emoticons/default/aktion035.gif) |
stevegm |
Dec 31 2014, 07:52 PM
I just took the side window, vent window, and channel off the driver's side of my '72. This thread inspired me. I had been putting it off. I didn't have to drill any screws out. But, one was a real PITA. Does anyone know if the aluminum channels for the window fuzzy are available anywhere NOS?
Harpo |
Jan 1 2015, 10:27 AM
I'm not sure which P/N is the fuzzy, window scraper or aluminum retainer for the scraper & fuzzy. I got my fuzzy & scraper from Mickey. Stoddards nor Sierra Madre carry the aluminum channel.
Lo-Fi Version | Time is now: 8th June 2024 - 09:04 PM |
