bhfast |
live it loud, balls out ![]() ![]() Group: Members Posts: 83 Joined: 30-December 02 From: Chandler, AZ/Daytona Beach, FL Member No.: 48 Region Association: Southwest Region ![]() |
I am looking for some strut gland nuts for SC/carrera struts(female threaded) and also these (in pics) shaft that goes into the trailing arms(I F 'ed up when I removed them). Not sure whether it would be easier to get new ones or try and fix the threads. (IMG:style_emoticons/default/confused24.gif)
any help is greatly appreciated. Brian Attached image(s) ![]() |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
I have those cross shafts. Shoot me back a shipping address and send me 20$ via Payal. That should cover shipping. They can go out today if you get back to me by 2:30
We dont use the cross shafts when converting to roller bearings. Your SOL on the struts nuts.. new shocks come with them. I throw away the old ones. B |
Brian_Boss |
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 ![]() |
Are you talking about stock Boge struts as would be on a '87 911? Are you needing the piece that is the first thing you remove when disassembling the strut (round with no flats, internally threaded)?
If so, I'm pretty there are some in my trash can. They do have some minor pipe wrench marks since I was planning to trash them. Free if you want them. Brian Boss 2 non running 911's 0 914's at the moment 1st post - lurking for a while |
Brad Roberts |
Welcome Brian !
I spent 20 years in Arlington (trying to grow up) before moving to NorCal. B |
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
Hi Brian!
Thanks for jumping out of the shadows... and welcome! -Rusty |
bhfast |
That is indeed the part I need.
Brian Holcomb 1111 Loblolly Ln. Port Orange, FL 32129 let me know how much for shipping I'll send money Brian |
Brad Roberts |
Ahh he needs the shock collar. Not the bolt that holds the shock to the chassis.
Just FYI.. Your 914 shocks "shouldnt" work in the Carrera struts if that is what your trying to do. B |
bhfast |
that is what i " was planning" i was under the impression that the struts were the same with the exception of the hub and brake spacing. read it some where. it said that the 911 shocks had a different valving you should use the 914 part.
Brian please enlighten me |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
BHFAST,
that sounds like the wording from one of the catalogs....I can't remember which, maybe, oh yes it was on Paragon Products ask Dr. Koni page. |
bhfast |
I beleive that was the one. OK I just went and dug out my 914 struts they are the same size, tube diameter, with the exception of caliper spacing and the collar threads.
Brian (IMG:style_emoticons/default/unsure.gif) |
Brad Roberts |
The tube is the same.. but something is different.. I forget what is incorrect right this minute (100 things going on)
I know 914 Koni's dont fit Carrera struts unless you have the adapter collar from Paragon. B |
seanery |
It's a special kind of washer that centers the strut IIRC.
I'll find the link to the doc koni page and post it. |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Is this what you are looking for?
Jeff Attached image(s) ![]() |
Brad Roberts |
No he is looking for the shock collar (part that holds the shock into the strut).
Do you want to sell those (Koni's and all) ?? I'll be very very fair with the pricing. I need a Carrera setup with Koni's for a customers car.. Unless... those are currently under you car. I forgot to invite you to lunch on Sunday with us... we left not too long after you did. B |
Jeffs9146 |
Thanks Brad but I went water-skiing at 11:00 so I couldn't go to lunch anyway!
Sure you can have them for the price of a good lunch! They still have the front rotors and stuff attached and you have to take it all!! lol Let me know what you want! Jeff Attached image(s) ![]() |
Brad Roberts |
Interesting.. Bilstein covers... Koni adjustable shocks.. 4lug suspension.
You do know.. those are Koni adjustables in the 4 lug setup.. correct ?? or did I just stick my foot in my mouth and let you on to something you didnt know ?? DOH !!! B |
Brad Roberts |
How about the SSI's in the corner ??
I do want your front struts.. I need to them to role cars around on while the 5 lug stuff gets rebuilt/powder coated on project cars. B |
Jeffs9146 |
I plan on using the ss heat exchangers but the front is the 4-lug setup I removed when I went to 86 sc front 5-lug. If you can use them I have offered them to a few people but I didn't want to ship them all the way to the East Coast. Get them outa here! What else do you need? I got more!
Jeff |
Brian_Boss |
Thanks for the welcome.
Brian - I found the pieces I believe you want. Take a look at the picture and make sure I understood correctly before I make a trip to the post office. BB Edit- well so much for the picture Edit2 - OK, I put it in as a link and it works. Thanks seanery. (IMG:http://www.concordeacceptance.com/images/nut1.jpg) This post has been edited by Brian_Boss: Jun 4 2003, 08:37 AM |
seanery |
you may have to have more posts to do a pic.
mail it to me and i'll post it. seanery at msn dot com |
Lo-Fi Version | Time is now: 13th June 2024 - 06:27 PM |
