Steering column wiggle... |
falcor75 |
Jan 18 2015, 04:30 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I've got some wiggle in the steering column, mostly toward the steering wheel end of the shaft. I've taken the whole column apart and figured I'd replace both bearings and the large metal clip.
My car is a '74 but the parts diagram doesnt show the upper bearing? Anyone got a part number for it? (IMG:style_emoticons/default/blink.gif) |
sixaddict |
Jan 18 2015, 05:45 AM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
91434771100...One happened to be on my bench awaiting installation..>Amazing that I found it (IMG:style_emoticons/default/biggrin.gif)
I've got some wiggle in the steering column, mostly toward the steering wheel end of the shaft. I've taken the whole column apart and figured I'd replace both bearings and the large metal clip. My car is a '74 but the parts diagram doesnt show the upper bearing? Anyone got a part number for it? (IMG:style_emoticons/default/blink.gif) |
falcor75 |
Jan 18 2015, 05:51 AM
Hmmm...is that bearing gold plated? The vendor here in Sweden that usually has good prices on most parts wants $300 for that bearing?
bdstone914 |
Jan 18 2015, 09:40 PM
bdstone914 Group: Members Posts: 4,525 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hmmm...is that bearing gold plated? The vendor here in Sweden that usually has good prices on most parts wants $300 for that bearing? Make sure it is the bearing that is bad and not the crush sleeve. I have a good bearing i just removed from a housing which you can have for the cost of postage. Usually it is just the crush sleeve. It is a 928 number. There have been a couple of recent threads of this subject. Bruce Attached thumbnail(s) |
falcor75 |
Jan 18 2015, 11:10 PM
Mine felt a bit notchy, I'll try cleaning it out with some brakecleaner and compressed air and then lube it up again before calling it dead.
If its dead I'll try my local SKF dealer to see if they have anything that could work. Thanks for offering your spare, 914world is awsome. (IMG:style_emoticons/default/smile.gif) |
falcor75 |
Jan 23 2015, 08:44 AM
I cleaned my both bearings and lubed them up today and reinstalled them.
Sadly it seems that my problem isnt the bearing but the housing itself. The wiggle is most evident in the up/down direction, much less in the left/right direction. Could it be that previous owners has pulled themselves out of the car on the steering wheel with enough weight to damage the housing? |
bdstone914 |
Jan 23 2015, 08:51 AM
I cleaned my both bearings and lubed them up today and reinstalled them. Sadly it seems that my problem isnt the bearing but the housing itself. The wiggle is most evident in the up/down direction, much less in the left/right direction. Could it be that previous owners has pulled themselves out of the car on the steering wheel with enough weight to damage the housing? If the bearing seat is damaged i would think you would see a gap. I have spare housings. Bruce |
falcor75 |
Jan 23 2015, 09:18 AM
I hope this link to a short video of the wiggle works, around the 20s mark is the best view of it. To me it looks like the whole bearing is moving which I guess means the housing is buggered?
https://dl.dropboxusercontent.com/u/3413880...9%2042%2014.mov |
falcor75 |
Jan 24 2015, 12:58 AM
Anyone with a second opinion? (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 23rd May 2024 - 04:35 PM |
