> Will fuel injection work with a 1911cc engine, with an 86a grind cam?
stevegm
post Jan 21 2015, 03:15 PM
I have a 1911cc engine that has an 86a grind cam. The specs for the cam are here:
http://vwparts.aircooled.net/Web-Cam-Type-...-5-p/00-082.htm
I am trying to figure out if this engine (1911cc), and cam, will work with D-jetronic fuel injection. Anybody know or have experience with this?
Replies(1 - 7)
914werke
post Jan 21 2015, 03:22 PM
I believe the 86 is for carb's & the "a" is for FI, so yes it can work with D-Jet and a correctly configured 1911.
Ive done it (IMG:style_emoticons/default/smile.gif) although my engine didn't use that Web cam
malcolm2
post Jan 21 2015, 03:23 PM
QUOTE(stevegm @ Jan 21 2015, 03:15 PM) *
I have the 1911 with L-jet. I adjusted the AFM gear about 11 teeth IIRC. Found the how-to online. I'll see if I can find it, there may be some D-jet info there too. I have a Daily Driver Cam from TIV store.com, #9550 and went with Jake's recommendation on CR of less than 8.
Can't help with the D-jet, but as you know the World will come to the rescue.
Mark Henry
post Jan 21 2015, 03:34 PM
that's what I do!
I'm pretty sure it won't, too much duration. But I've never used this cam.
It looks a lot like a Scat C-25 which is a mild carb cam.
Would work good with a d-jet intake with MegaSquirt.
Mark Henry
post Jan 21 2015, 03:38 PM
that's what I do!
QUOTE(malcolm2 @ Jan 21 2015, 04:23 PM) *
I believe 9550 was a djet FI cam, a modified WEB73
Mark Henry
post Jan 21 2015, 04:06 PM
that's what I do!
QUOTE(Mark Henry @ Jan 21 2015, 04:34 PM) *
I'm soon going to put up for sale a set of modified 1.8 manifolds that allow you to mount all the 2.0 d-jet parts (plenum, TB, air cleaner, etc) on 4 bolt heads.
Then you could megasquirt the engine.
This is a known running combo that I ran with a 2.0 scat C-25cam with SDS FI and later a stock 1.8
I also might still have all the intake/injector bits, just no brain.
PM me if interested.
Woody
post Jan 21 2015, 09:05 PM
Sandbox Rabblerouser and head toilet scrubber
That cam will not work with factory injection
Jake Raby
post Jan 21 2015, 10:28 PM
Engine Surgeon
It'll run fine... At wide ass open throttle! You'll have no idle, no midrange and no tenability, though.
- Lo-Fi Version Time is now: 25th June 2026 - 07:27 PM
