> Battery Tray Installation, Paint?
Allan
post Feb 5 2005, 07:07 PM
Teenerless Weenie
How do you guys do the paint when replacing the battery tray and support. It's like, once the support and tray are in, how do you paint inside it. I was thinking maybe put in the support, paint, grint off enough to weld on the tray and then do it all over again. Tips?
Replies(1 - 10)
Allan
post Feb 5 2005, 09:34 PM
Teenerless Weenie
Well? (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
xsboost90
post Feb 5 2005, 09:52 PM
interesting question. grab a brush and some POR15 i say... or paint, weld and repaint but that may make the paint peel off and rust...yuck.
Allan
post Feb 6 2005, 12:06 PM
Teenerless Weenie
Has anyone tried bolting the tray to the support and to the inner fender well so it can be removed periodically for cleaning?
DuckRyder
post Feb 6 2005, 12:18 PM
Avatars Mode: OFF because of the recalcitrant few.
I was hoping that some of the Gurus would throw in two cents. Since I'm about to go through this.
I had also thought of riviting or screwing it into place short term since It looks likes its going to be quite difficult to weld with the engine in. I'm planning to pull the engine next winter and paint the engine compartment, fix the engine shelf (cut for A/C) and replace the tin and wiring.
My plan was to paint the battery tray out of the car, and remove the paint from the welding surfaces, replacing it with weldable primer, and temporarily rivit it in.
I'm in no way suggesting that my plan is the right way, only way, preffered way, in fact, I don't even know if it will work at all... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) But that is my plan.
FWIW
jwalters
post Feb 6 2005, 12:30 PM
Sooo Close.......
Region Association: Europe
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Honestly and truley--because nobody will ever see it--use cold galvanising compund--comes in a spray at your local home labrynth--it is 94% pure zinc and will last a lifetime against rust---that is what I am using prior to my welding--I grind the metal down and then zinc it with this stuff--then weld it up--it is fantastic stuff--and if you go easy with the heat it will not lift--no adverse effects with welding at all--conducts trons very well--- (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
McMark
post Feb 6 2005, 02:46 PM
914 Freak!
I have had the pieces painted before install and then touched up where the welds are. Didn't work as well as I would have wanted, but was 90% there. There is no good way. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
GWN7
post Feb 6 2005, 02:49 PM
King of Road Trips
It was also suggested in a thread a long time ago to weld in bolts to the body and use them like studs to bolt the battery tray in place. (not recommended if your going for the CW look)
ejm
post Feb 6 2005, 02:58 PM
I can see the light at the end of the tunnel
Hard part is welding the tray to the support since you can't see under there. Here's the trick....weld in the support then hold the tray in place and scribe the outline of the support. Then drill 1/4" holes in the tray and plug weld it to the support from the top.
jwalters
post Feb 6 2005, 03:00 PM
Sooo Close.......
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Use my method--I would never ever steer anybody in the wrong direction--it works very well--- (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
jwalters
post Feb 6 2005, 03:06 PM
Sooo Close.......
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
- Lo-Fi Version Time is now: 8th July 2025 - 03:41 PM
