> 915 CV, help me remember
Dr Evil
post Jan 25 2015, 10:20 AM
Send me your transmission!
When someone puts the larger flanged 915 output flanges on their transmission, can they use a 915 CV on one side and a smaller 914 CV on the outside? I forget if the inner splines are the same. My memory stops at the end of the flange (IMG:style_emoticons/default/wink.gif)
This is for an LSD build so that needs special flanges and we can only find 915 ones. If anyone has the smaller dia output flanges for an LSD, we would be interested.
Replies(1 - 7)
Cap'n Krusty
post Jan 25 2015, 10:28 AM
Cap'n Krusty
915 CV joints are splined for Porsche axles, 914 CV joints are splined for VW axles. (That's the difference between 914/6 CV joints and the 914/4 ones, too.)
The Cap'n
JFJ914
post Jan 25 2015, 10:35 AM
Use the 944 100mm CV. It has the VW spline count. The stock axle will also need machining to accommodate the wider CV.
Randal
post Jan 25 2015, 01:47 PM
QUOTE(John Jentz @ Jan 25 2015, 08:35 AM) *
I used a 915 output shaft, 944 turbo CV (inboard) and the same thing outboard as I have a 5 bolt conversion.
Can't remember what the axles are, maybe turbo 944, but they didn't have to be modified.
There are some great write ups on doing this conversion on this site. Including the one that I used that lists all the parts necessary. Or maybe it was Andy who told me, which is likely.
Dr Evil
post Jan 25 2015, 05:24 PM
That is what I was blanking on, the 944 part. Been a long time since I thought about it. Thanks (IMG:style_emoticons/default/smile.gif)
sixnotfour
post Jan 25 2015, 06:25 PM
Where is your patient chart Doc??
Dr Evil
post Jan 25 2015, 06:34 PM
Do what now? (IMG:style_emoticons/default/blink.gif)
pdlightning
post Jan 26 2015, 01:24 AM
Pdlightning
I used a 915 and modified the flanges to 108 mm in order to use 930/ turbo CV and axles on both ends.
- Lo-Fi Version Time is now: 12th March 2026 - 06:29 AM
