QUOTE(John Jentz @ Jan 25 2015, 08:35 AM)
Use the 944 100mm CV. It has the VW spline count. The stock axle will also need machining to accommodate the wider CV.
I used a 915 output shaft, 944 turbo CV (inboard) and the same thing outboard as I have a 5 bolt conversion.
Can't remember what the axles are, maybe turbo 944, but they didn't have to be modified.
There are some great write ups on doing this conversion on this site. Including the one that I used that lists all the parts necessary. Or maybe it was Andy who told me, which is likely.
