Setting timing for carb s question |
rosenfe |
Feb 12 2015, 09:09 AM
Senior Member Group: Members Posts: 557 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
Pelican tech article mentions 34-35 btc as a good setting.any opinions?
Steve Snyder |
Feb 12 2015, 05:33 PM
Member Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
Seems high to me. I'm at 27.
Dave_Darling |
Feb 12 2015, 06:36 PM
Which distributor? What cam? Which carbs? Engine configuration? Exhaust?
All of those have at least some influence on what timing is needed. The best way to set it is probably to use a dyno with a good set of gauges, including cylinder head temps for all four cylinders. --DD |
Steve Snyder |
Feb 12 2015, 07:47 PM
Well, in that case you would also need the exhaust gas temps for all four cylinders.
(IMG:style_emoticons/default/poke.gif) ...and 35 will still be high. (IMG:style_emoticons/default/biggrin.gif) |
somd914 |
Feb 12 2015, 08:23 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I'm running a 2056, Webcam 86 cam, Weber 40 IDFs, Pertronix SVDA distributor.
I've found 27-29 works well for my config. But I don't have a CHT gauge. |
rosenfe |
Feb 12 2015, 09:09 PM
weber 34 ,stock cam,distributor.ill just stay with 27.wondering why pelican article indicated 35 btdc?
Lo-Fi Version | Time is now: 4th June 2024 - 04:03 PM |
