Replacement bolts for rear shock to trailing arm, longer to accommodate tie downs? |
stugray |
Feb 28 2015, 03:47 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I bought these tie downs:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1425160022.1.png) But the stock bolts seem to be a little short to stick the tie down between the shock & trailing arm while retaining the thick washer under the stock bolt head. The stock bolt is 18mm X 1.5 X 130mm. The tie down is 5mm. Bolts that large typically come in 10mm increments, so I would need 18mm X 1.5 X 140mm. I have found them but for $25 ea plus shipping. Anyone have a source for the bolts cheaper or a trick to installing these with the stock bolts? Are the bolts that have the attachment points for the rear swaybars just a tiny bit longer? |
zambezi |
Feb 28 2015, 04:00 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Could you use the tie down to replace the washer? You would then be about the same spacing
Harpo |
Mar 1 2015, 07:52 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I will check at work tomorrow and let you know what I find
David |
Mikey914 |
Mar 1 2015, 10:50 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You would be creating more of a lever to possibly bend the bolt. Personally I'd keep it where you have it, and get a longer bolt. I may be able to get you better pricing. I'll check in the morning, sounds like its possible. What is the grade?
Harpo |
Mar 2 2015, 04:18 PM
I pulled two M18-1.5x135mm class 10.9 bolts out of the stockroom. I will go pick them up tomorrow. PM me your address and they are yours for free.
David |
stugray |
Mar 2 2015, 05:07 PM
I pulled two M18-1.5x135mm class 10.9 bolts out of the stockroom. I will go pick them up tomorrow. PM me your address and they are yours for free. David Holy Crap! Thanks a LOT! I was just looking for a cheaper source. That is infinitely cheaper! I have a lot of parts I am trying to get rid of. If you need a part and I have it, it's yours! Let me know. PM sent |
siverson |
Mar 2 2015, 07:43 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
That is very nice of you, but I'm actually still curious - where can these be bought?
This is as close as I could find: http://www.marshallshardware.com/products/...=9275&lid=1 McMaster, etc doesn't seem to have this 135mm, 1.5 pitch. -Steve |
Harpo |
Mar 5 2015, 04:02 PM
campbellcj |
Mar 6 2015, 10:57 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I've been using the stock swaybar bolts with those tie-downs for years. No probs.
stugray |
Mar 7 2015, 12:05 AM
I've been using the stock swaybar bolts with those tie-downs for years. No probs. Thanks. That why I asked if the swaybar bolts were just a little longer than 130mm. Or maybe my shocks are just a little wider than normal? (IMG:style_emoticons/default/confused24.gif) I know I could have left out the thick washer and it would work, but it looks like the head of the stock bolt would dig into the shock mating surface if I did that. Any way, it looks like Harpo has me covered. Thanks Harpo! |
Bartlett 914 |
Mar 7 2015, 07:40 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:20 AM |
