Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
I'd like to get the cooler installed by the time Hershey rolls around, I've looked at past threads but didn't see any definitive pics, and i'm wondering if it's necessary to use banjo fittings on the plate to make things fit (as suggested by an air cooled site) I'd like to go up through the tin then back to the cooler, but I'm open to any suggestions.
The banjo fittings seem to double the cost of the plate, and that's what works best, fine, if not, alternatives are gently appreciated. Thanks, Joe |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
The sandwich plate I use has an integral thermostat. My routing is similar to Dave's. My cooler is mounted under the rear trunk on the left side. I used a 3 inch duct with a scoop in the rocker panel to direct air to the cooler.
Attached image(s) ![]() ![]() ![]() |
Porschef |
Elliot, I see yourenrunning headers, which leaves a lot more room. Dave, did you remove some of the heat plumbing? Looks like that may be necessary?
I'll need to get under the car this weekend, I was looking for a head start. More snow headed here tomorrow, so it'll be a while before she hits the road... (IMG:style_emoticons/default/sad.gif) |
Dave_Darling |
I removed the passenger's side heater ducting to allow for the hose routing. Both the S-duct and J-tube were removed, though I think I kept the flapper valve.
If you go up from the sandwich plate, you'll get into the area of the stock oil cooler. I'm not sure how much room there is around there. --DD |
JimN73 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest ![]() |
Most sandwich plates without the built-in thermostat should work, most with the built-in thermostat will not. AirCooled.net has one with the thermostat that will work - expensive but maybe worth it.
Lo-Fi Version | Time is now: 10th June 2024 - 08:33 PM |
