sail panel trim removal, how ? |
got914? |
Mar 7 2015, 12:54 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
ok i got the phillips screw at the top out but it doesnt seem to want to let go.
Hows the clip or attachment to the bottom edge ? I dont want to break it. |
cn2800 |
Mar 7 2015, 01:32 PM
Member Group: Members Posts: 119 Joined: 11-August 14 From: Amarillo, Texas Member No.: 17,766 Region Association: None |
I had the same question. Turns out it's an 8mm nut on the upper inside of the rear fender. It is likely hidden beneath a few layers of undercoating and muck. I don't know if you can get to it at all without removing the rear wheel. These photos show what you're dealing with:
Don't forget that at the top (the phillips screw) there's a plastic barrel spacer between the trim and the body. It's there to prevent over-tightening the screw and bending the trim. Don't loose it when you finally remove the trim. Or if you loose it, don't forget to make/buy another one before you reinstall the trim. |
got914? |
Mar 7 2015, 01:40 PM
Thanks.
Exactly what I was looking for. |
stugray |
Mar 7 2015, 02:02 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I just did this the other day too.
I needed a 8mm 1/4"-drive deep socket. I also had to get the wheels off, get up in there with a wire brush and some WD-40 to clear all the undercoating and rust first. BTW - if you are in the mood for a turretts laden moment (or two hours), just try to get the little plastic clip/disks off of the engine cover end pieces shown missing in the pictures above while having a bad back.... |
Lo-Fi Version | Time is now: 8th June 2024 - 08:35 PM |
