Mocal sandwich plate, W Banjo bolts |
Porschef |
Mar 10 2015, 03:47 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Going back and forth on this one, is it really necessary for fitment to use this style?
http://www.racerpartswholesale.com/product..._Sandwich_Plate Has anyone used one? A member here hooked me up with a cooler, some hose and fittings, I've read Dave's and others threads regarding installations but don't know if this was used or not... |
screenguy914 |
Mar 10 2015, 04:25 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
It's an oil filter adapter with fittings for in/out oil lines. Are there other options to plumb a cooler into the lube system?
I suggest including a thermostat in the external cooler system. With this, oil will bypass the cooler until oil temp. reaches a threshold - lowers pumping losses with more viscous, cold oil. http://www.racerpartswholesale.com/product...rmostat#reviews Notice the hose size? Larger hose ID allows oil flow with less restriction (pressure drop) and again, less stress on the oil pump. Sherwood |
StratPlayer |
Mar 10 2015, 04:41 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
You can get a sandwich plate a lot cheaper that will do just as good a job as that mocal one.
Elliot Cannon |
Mar 10 2015, 04:48 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I use a sandwich plate like this one. I use one with the 180 degree thermostat and it works great. I didn't use "banjo" fittings. I didn't really need them. You might however not have the same amount of clearance I have since I have headers installed. Whichever fittings you use, the sandwich plate should work fine. It has for me.
Attached image(s) |
Porschef |
Mar 10 2015, 05:38 PM
Elliot, yes I did see your pic before, it's just that the header pipe gets in the way and it's hard to tell just what's going on. But you didn't need the banjo bolts,correct?
Strat, I do realize there are less expensive ones out there, the Mocal unit is the only one shown with those bolts, Aircooled.net also shows the same for the type4... Sherwood, I do have a remote thermostat, it's an Earls that is essentially the same as the one you're referencing. I was just making an attempt at simplification, eliminating extra fittings/plumbing |
stugray |
Mar 10 2015, 06:22 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I used this one:
http://www.summitracing.com/parts/ctr-22-545 (IMG:http://static.summitracing.com/global/images/prod/mediumlarge/ctr-22-545_w_ml.jpg) and some -12 AN to Male 1/2 in fittings. Pricey but solid. |
Elliot Cannon |
Mar 10 2015, 07:35 PM
Elliot, yes I did see your pic before, it's just that the header pipe gets in the way and it's hard to tell just what's going on. But you didn't need the banjo bolts,correct? Strat, I do realize there are less expensive ones out there, the Mocal unit is the only one shown with those bolts, Aircooled.net also shows the same for the type4... Sherwood, I do have a remote thermostat, it's an Earls that is essentially the same as the one you're referencing. I was just making an attempt at simplification, eliminating extra fittings/plumbing You might try something like his AN fitting if you have room. It might be a bit cheaper than banjo fittings. Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:58 AM |
