Time for another round of guess the part, New part that I'll be producing in the next few weeks |
Mikey914 |
Mar 16 2015, 09:59 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Lets see how long it takes to figure out this one.
Attached thumbnail(s) |
JoeDees |
Mar 16 2015, 10:21 AM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
Too easy, it's the whatchamacallit!
Bob L. |
Mar 16 2015, 10:28 AM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
looks like a grommet for a specific place. Where... (IMG:style_emoticons/default/confused24.gif)
Mikey914 |
Mar 16 2015, 10:29 AM
Yep, a hint, you have to be into a bare bones restoration to find this one. |
Jeffs9146 |
Mar 16 2015, 10:32 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Engine compartment to trunk wire gromet (IMG:style_emoticons/default/idea.gif)
PanelBilly |
Mar 16 2015, 10:45 AM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I'm still waiting for the new sail panel trim. Let's get things made in the order that I need them!
Mikey914 |
Mar 16 2015, 10:52 AM
I'm still waiting for the new sail panel trim. Let's get things made in the order that I need them! The sail panel trim is still on the back burner as the factory are now available. I will continue to evaluate how I can make them, the castings were a bust as the labor to polish made them more expensive than the OEM. I threw a chunk of cash at the process so far and have to get back to where I can try another option. Meanwhile I do the stuff I can easily do to help pay for the R&D. I haven't forgotten them. |
Targa70 |
Mar 16 2015, 11:09 AM
Member Group: Members Posts: 80 Joined: 22-March 13 From: Virginia Member No.: 15,683 Region Association: None |
behind the rocker panel covers? The gromets on the drivers side thru which the vent line runs from top of the fuel tank to engine compartment?
McMark |
Mar 16 2015, 11:43 AM
Only place I can think of, but I'm not sure of, is around the wiring harness, where it passes from engine bay to trunk, or gas tank area to trunk.
Java2570 |
Mar 16 2015, 11:45 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Looks like the grommet for the ECU wiring harness.
JamesM |
Mar 16 2015, 11:46 AM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
D-jet Harness, grommet at the ECU.
JamesM |
Mar 16 2015, 11:47 AM
McMark |
Mar 16 2015, 11:51 AM
Aha! Good one! (IMG:style_emoticons/default/sunglasses.gif)
TJB/914 |
Mar 16 2015, 12:00 PM
Mid-Engn. Group: Members Posts: 4,336 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
D-jet Harness, grommet at the ECU. Yep, as soon as I saw this post (IMG:style_emoticons/default/w00t.gif) !!! Tom |
Mikey914 |
Mar 16 2015, 12:08 PM
That went fast. I guess you know your 914's more intimately than I thought.
Dave_Darling |
Mar 16 2015, 09:18 PM
I knew I had messed with that damn thing before, but I couldn't remember where it was! As soon as I saw Java's post, I exclaimed "That's it!!"
--DD |
JamesM |
Mar 16 2015, 09:30 PM
So I am going to go out on a limb here and guess that you made these for Bowlsby? Unless these are really stretchy I don't imagine many people would want to attempt to replace one.
Mikey914 |
Mar 17 2015, 12:16 AM
Yes these are a few other choice parts were made for Jeff. I covered the tooling on these to be able to make these available to all, the rest of the parts are a Jeff exclusive deal. They are s silicone so yes the are stretchy, but you will need the ends off to use them.
falcor75 |
Mar 17 2015, 12:23 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Dammit I was hoping for something else.... (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 12:37 AM |
