Frustrating amp wiring of death!!! |
Gobstopper |
Feb 12 2005, 08:57 PM
Newbie Group: Members Posts: 38 Joined: 9-August 04 From: Camano Island, Wa Member No.: 2,496 |
Im curently wiring up an amplifier for the stereo in my car. Ive already fed the power wire from the front trunk to the passenger compartment.
But now I can't find the grommet that leads from the passenger compartment to the engine compartment, could someone give me a general idea of where to look. Thanks |
xsboost90 |
Feb 12 2005, 09:04 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
1/2" drill and a trip to autozone should take care of that.
r_towle |
Feb 12 2005, 09:07 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
in the tunnel, there should be an access panel on top of the rear part of the tunnel.
Rich |
ejm |
Feb 12 2005, 09:09 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The factory harness is somewhat hard to follow from the cabin to the engine compartment. It's inside a rubber boot and makes a couple of tight bends. I would route the cable inside along the passenger side long and enter the engine compartment on top of the long, just below the battery. Put a fuse right at the battery to avoid excitement if your wiring shorts out.
Gobstopper |
Feb 12 2005, 09:10 PM
Thanks ejm
Hammy |
Feb 12 2005, 09:58 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
So does mounting an amp in the front trunk require a personal custom job instead of taking it to a car stereo shop for the install? They probably won't know what to do I assume.
Gobstopper |
Feb 12 2005, 10:11 PM
I never have trusted car stereo shops. I used to have them install my cd decks, but both times ive had to fix wiring problems.
The 914 was easy to install my deck in, since I could just pull the wiring down from in the dash. My other car (81 mustang-beater ready for the junkyard) was easy to install an amp in, but the 914 is a pain. I havent figured out how I want to mount the amp yet, since Im dont want to drill holes anywhere |
TheCabinetmaker |
Feb 12 2005, 10:28 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I ran my power wire down the passenger long to the front trunk using the holes provided by the AC unit I ripped out. Amp and CD changer are both mounted to the bulkhead in front of the fuel tank. wiring to the cockpit from there was easy. I too would never take any car to a stereo shop.
ejm |
Feb 13 2005, 06:38 AM
Bulkhead is the usual mounting place...Don't drill into the fuel tank!! Small holes in the fuzzy carpet aren't too noticeable if you remove the amp later. Also, the ground wire for the amp carries as much current as the power lead. It needs to go to a good ground point, not under one of the amps mounting screws. |
DJsRepS |
Feb 27 2005, 05:57 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
I mounted my FI brain in the rear trunk and just sitting in the hot FL sun in a sealed trunk I could not even touch the thing. It was a 100% cooler leaving it in the motor bay where the German's stuck it. Im not saying to mount your amp there but it would keep it alot cooler and the 12v batt supply is right there. I would mount it near or under the glove box.
Lo-Fi Version | Time is now: 9th June 2024 - 01:22 PM |
