Fresh air blower removal help |
Harpo |
Mar 22 2015, 06:09 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good morning 914 world,
I need to remove my fresh air blower assembly prior to going to paint. I have tried a search but no luck. I really only want to be able to remove the grill under the cowl so I can replace with my new one from 914rubber after paint. Thanks David |
TheCabinetmaker |
Mar 22 2015, 06:54 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Remove fuel tank then pretty much everything you see behind it.
Harpo |
Mar 22 2015, 07:51 AM
The fuel tank is out. Where are there fasteners holding the blower in place?
Thanks |
BeatNavy |
Mar 22 2015, 08:08 AM
There are three (or is it four?) bolts on the side that bolt UP on the top part of the blower box assembly. They are underneath the cowl. Of course you have to disconnect the control cables (take a picture so you know how they are oriented!), the 4 prong connector in the back, and the actual fresh air tubes.
Harpo |
Mar 22 2015, 10:24 AM
Thanks everyone, I found the two screws and pulled out the fresh air blower.
David |
Lo-Fi Version | Time is now: 7th June 2024 - 09:54 AM |
