/6 tanks - did you loctite or thread sealant the 2 mounting bolts? |
patssle |
Mar 27 2015, 07:54 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Just curious what others did and if they leaked. I think mine is slightly leaking from the forward mounting bolt. I don't know why they are threaded all the way though into the tank...just makes leaking a possibility!
rgalla9146 |
Mar 27 2015, 08:43 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Bolts ?
They should be studs. Permanently part of the tank. No chance for leakage. |
mepstein |
Mar 27 2015, 08:46 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Bolts ? They should be studs. Permanently part of the tank. No chance for leakage. (IMG:style_emoticons/default/agree.gif) mine are on an original 6 tank |
patssle |
Mar 27 2015, 08:48 PM
Ahhh guess you pay for what you get. My aftermarket Vellios tank is thread tapped all the way through. Stupid but probably cheaper/easier or something to build.
t collins |
Mar 27 2015, 09:03 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I loctited threated studs in my Vellios tank, so far so good.
bigkensteele |
Mar 27 2015, 09:07 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Ahhh guess you pay for what you get. My aftermarket Vellios tank is thread tapped all the way through. Stupid but probably cheaper/easier or something to build. Man, I am really learning a lot about the tank sitting on my shelf from your trials and tribulations. I am becoming concerned about mine, even though I probably won't be installing it anytime soon. If I recall correctly, you also had the oil filter fitting drilled off-center, and it seems there was something else besides the subject of this thread... ??? |
t collins |
Mar 27 2015, 09:23 PM
[/quote] I heard some of the tanks didn't have an internal perforated baffle, easy to check if you'll look in the fill hole. |
patssle |
Mar 27 2015, 09:31 PM
Man, I am really learning a lot about the tank sitting on my shelf from your trials and tribulations. I am becoming concerned about mine, even though I probably won't be installing it anytime soon. If I recall correctly, you also had the oil filter fitting drilled off-center, and it seems there was something else besides the subject of this thread... ??? Yeah that was my tank. But you know - it became a gift in the end. It forced me to go with a remote oil filter mount (after a TON of research to find what would work) which allowed to install an oil temp sensor into the mount (and a gauge into the center console). Then last month I installed an oil cooler and put the fan temp sensor into the filter mount as well. No couplings or sensors obstructing oil flow. Just measure and see if yours was drilled center - easy to find out! |
Lo-Fi Version | Time is now: 6th June 2024 - 07:47 PM |
