WTB: Clutch Pedal Roll Pin |
kkid |
Apr 7 2015, 05:23 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
My clutch pedal went down.
The roll pin is broken in pieces. It has the bronze bushing kit already installed by a PO. So I will need a pin only. If you're a local that would be great! Please let me know if you have one. Thanks in advance, kkid (IMG:style_emoticons/default/smile.gif) |
partwerks |
Apr 7 2015, 05:39 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I believe I have an extra used one, but is located where the car is being worked on, and may not get to where it is at till the weekend.
wildman |
Apr 7 2015, 05:45 PM
Newbie Group: Members Posts: 34 Joined: 24-May 11 From: Oklahoma City, OK Member No.: 13,112 Region Association: Southwest Region |
If you're in a hurry check with your local hardware store, they may not have the correct metric size roll pin but they may have an English size close. (roll pins usually squeeze down quite a bit and can be cut to length) I've even been known to use a dremel to open up the slit on a roll pin so that it will squeeze down to a smaller diameter if I'm in a real pinch.
kkid |
Apr 7 2015, 05:54 PM
kkid |
Apr 7 2015, 05:59 PM
If you're in a hurry check with your local hardware store, they may not have the correct metric size roll pin but they may have an English size close. (roll pins usually squeeze down quite a bit and can be cut to length) I've even been known to use a dremel to open up the slit on a roll pin so that it will squeeze down to a smaller diameter if I'm in a real pinch. yeah I went to my local store and found a slotted type that is closer to our spec. But the slit is very small so I didn't even try that one. |
kkid |
Apr 7 2015, 06:10 PM
I have just placed an order on PP. It's a 6x28mm size pin(900-309-002-00), $1.50. It will arrive on Friday.
But again, if you have one in my area please let me know. The sooner, the better for the daily driver. Thanks, kkid (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 04:57 PM |
