> High Amp Alternator, bolt in application
McMark
post Apr 13 2015, 04:03 PM
914 Freak!
I needed a new alternator for the Turbo 1.7 car and with all of the upgrades I've done I thought I'd look around for a higher amperage unit to install. I know this has been done before, but I wanted something that was a more natural fit. And while I was looking, something with 'modern' technology would be nice.
I found a unit that looked promising and took the leap. It's a built to order, made in the USA unit. It features a built in regulator for a single wire installation, and it's 150 amps (also available in 240 amp! (IMG:style_emoticons/default/ohmy.gif) ).
It finally arrived last week and holding it roughly in place nothing jumped out as a major problem, but there were a few tweaks to the housing. So a little trimming of the two mounting points, a bushing to reduce the pivot shaft diameter to 8mm, and drilling the top mount to 8mm it fits perfectly. Works just like an original unit, has MORE clearance than a stock unit although it weighs quite a bit more. (IMG:style_emoticons/default/wink.gif)
I want to get this installed in my car before I make any promises, but this is looking like a REALLY easy upgrade. NO MORE VOLTAGE REGULATOR!!! (IMG:style_emoticons/default/aktion035.gif)
Replies(1 - 19)
Elliot Cannon
post Apr 13 2015, 04:27 PM
Group: Retired Members
So, what happens when the voltage regulator fails? How much heavier and what might be the cost?
Krieger
post Apr 13 2015, 04:33 PM
Good work!
Geezer914
post Apr 13 2015, 04:47 PM
Geezer914
Pulley fan or rear cooling duck???
Kansas 914
post Apr 13 2015, 05:27 PM
QUOTE(Geezer914 @ Apr 13 2015, 04:47 PM) *
McMark
post Apr 13 2015, 05:43 PM
914 Freak!
The alternator is sold just as it's shown. I am probably going to merge a 914 alternator rear housing and the one that came on this unit. Should be able to make that work pretty easily.
The VR may be replaceable, but I expect this new stuff to be much more robust. Which means, I expect to never have to touch this alternator/VR again ever. I didn't weigh it, but I would guess around double the weight. Cost TBD, but a rebuilt unit is under $100, and this will be at least triple that, plus... (IMG:style_emoticons/default/ph34r.gif)
McMark
post Apr 13 2015, 11:51 PM
914 Freak!
Looked and theres a fan inside. (IMG:style_emoticons/default/thumb3d.gif)
Elliot Cannon
post Apr 14 2015, 01:12 AM
QUOTE(Kansas 914 @ Apr 13 2015, 04:27 PM) *
euro911
post Apr 14 2015, 02:17 AM
Looks good, Mark. Will the OEM alternator tin fit (or will it need to be modified a bit)?
Bartlett 914
post Apr 14 2015, 06:45 AM
QUOTE(McMark @ Apr 14 2015, 12:51 AM) *
Looks like you are on a good find.
Was this alternator designed for a specific rotation? I believe the air should exit to the front. If it has an internal fan, will it be able to do this? No all fans can be reversed
McMark
post Apr 22 2015, 10:53 AM
914 Freak!
Just heard back that the alternator is the correct rotation for the Type 4.
worn
post Apr 22 2015, 11:03 AM
QUOTE(Elliot Cannon @ Apr 13 2015, 11:12 PM) *
Noticed that one too. Very common though. So much so that they named tape that way.
Elliot Cannon
post Apr 22 2015, 11:19 AM
QUOTE(worn @ Apr 22 2015, 10:03 AM) *
I think even the HVAC people spell it that way now. (IMG:style_emoticons/default/laugh.gif) It's about time. (IMG:style_emoticons/default/av-943.gif)
Kansas 914
post Apr 22 2015, 01:32 PM
QUOTE(Elliot Cannon @ Apr 22 2015, 11:19 AM) *
Bartlett 914
post Apr 22 2015, 01:53 PM
QUOTE(McMark @ Apr 22 2015, 11:53 AM) *
That is good news. Where does the air exit?
euro911
post Apr 22 2015, 06:36 PM
QUOTE(Kansas 914 @ Apr 22 2015, 12:32 PM) *
One of my hobbies involves tropospheric ducting (IMG:style_emoticons/default/shades.gif)
worn
post Apr 22 2015, 07:03 PM
There is warm air at the North Pole?
Also i can hardly wait Mark. Being decrepit and holding the alternator up there. Well, will the weight be an issue?
McMark
post Apr 22 2015, 09:14 PM
914 Freak!
I'll weigh it tomorrow... (IMG:style_emoticons/default/thumb3d.gif)
falcor75
post May 15 2015, 01:03 PM
Since I'm going the efi route I think I'm going to need one of these.... (IMG:style_emoticons/default/blink.gif)
McMark
post May 15 2015, 07:56 PM
914 Freak!
Efi doesn't need high amps. It's more hot big headlights, seat heaters, stereo, etc.
- Lo-Fi Version Time is now: 2nd April 2026 - 02:54 PM
