Fuel flow Question from a rookie, What should I expect? |
jack20 |
Apr 19 2015, 03:50 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
If I disconnect the fuel line forward of the fuel pump, what kind of flow should I be seeing from the tank. The tank has about 3 gal of fuel.
Thanks, Jack |
Mike Bellis |
Apr 19 2015, 03:57 PM
steady until empty... (IMG:style_emoticons/default/biggrin.gif)
pilothyer |
Apr 19 2015, 04:01 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If you mean disconnect the line from the pump on it's outlet port, you probably wouldn't see much flow, very little if any. On the other hand if you disconnect the line from the inlet port you will gravity flow the tank until empty.
TheCabinetmaker |
Apr 19 2015, 04:07 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'd guess you'll lose about three gallons.
jack20 |
Apr 19 2015, 06:40 PM
Thanks guys. I meant fuel filter not fuel pump. If I disconnect the line from the inlet side what should I expect in the way of flow. Sorry.
somd914 |
Apr 19 2015, 07:28 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Carbs or FI?
With D-Jet (can't speak for L-Jet) pump will come on for a few seconds when the ignition is switched on but then shut off until you start the engine. Pressure should be around 30 PSI if I recall correctly. As for carbs, mine is wired such that the fuel pump comes on with the ignition and remains on, pressure is 3 PSI. I'm not sure if I'm on the right track for what you are asking, but it appears that you don't have flow out of the pump before the filter, is that correct? If that is the case, do you ever hear the pump come on? |
worn |
Apr 19 2015, 07:50 PM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Thanks guys. I meant fuel filter not fuel pump. If I disconnect the line from the inlet side what should I expect in the way of flow. Sorry. You are trying to measure pump output eh? I would have to look it up, but it would be as described already. The stock FI would turn the pump on briefly. If you trick the pump relay, then you should be seeing a pretty steady stream. Tell us more. Even if I am an idiot the others in the bunch will have the answers. |
pilothyer |
Apr 19 2015, 08:58 PM
Thanks guys. I meant fuel filter not fuel pump. If I disconnect the line from the inlet side what should I expect in the way of flow. Sorry. If the sock in the tank isn't clogged you could expect free flow from the tank to the ground (IMG:style_emoticons/default/biggrin.gif) If you are trying to change the filter just squeeze off the line before you disconnect. |
jack20 |
Apr 20 2015, 12:34 AM
My car is a project that is very close to drivable. A week or so ago I changed the fuel hoses under the tank because I was in there anyway. Today I tried to start the car for the first time in weeks. Started OK before. Today it would chug a bit but not run. I checked fuel flo at the filter inlet. Very weak. I pulled up the tank an the hoses I installed fely very flimsy and prone to kinking. I bought these at bird thinking they were what I needed. That's why I'm asking about flow to the filter.
1974 2.0 FI |
euro911 |
Apr 20 2015, 12:53 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'd pull the tank again and check the internal filter (sock). It's quite possible that it's clogged with varnish.
Carefully remove and clean it or replace it if it's not in good shape. Be careful with the fiber washers too. |
TheCabinetmaker |
Apr 20 2015, 04:28 AM
Sounds like you switched the lines at the tank.
bdstone914 |
Apr 20 2015, 04:35 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
jack20 |
Apr 21 2015, 12:01 AM
Thanks for all the help. Turns out that the fuel lines I ordered were too flexible and cut off the fuel flow, which I what I suspected. I went to the FLAPS and got some overkill hoses and that solved the flow problem. Back on the road after six months of work. Feels great!
Lo-Fi Version | Time is now: 8th June 2024 - 12:07 PM |
