Case splitting |
Case splitting |
nsyr |
Feb 16 2005, 07:51 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
I am currently disassembling my engine and have gotten all the bolts and nuts off but I am having a difficult time getting the case to split. From what I understand it should come apart pretty easy? Any tips will be appreciated........
Jake Raby |
Feb 16 2005, 07:56 PM
Yes.... You have probably forgotten a bolt. There are several that are hidden including one between the pushrod tubes on the 3-4 side of the engine..
You really need this http://cpanel33.gzo.com/~ratboss/store/pro...09&cat=0&page=1 It's worth its weight in gold because I go over every single fastener on the engine and full disassembly and reassembly. The case should split super easy- If it doesn't you have forgotten a fastener.. |
scotty b |
Feb 16 2005, 07:59 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
There is actually a case splitting too lmade for VW engines if you have time to wait for a shipment. Most all VW shops carry it. It is basically a screw with a pad on either end and you turn a nut in the niddle to expand the sides. If you don't use that just be carefull not to put anything (screwdriver) in between the halves to pry with.
TheCabinetmaker |
Feb 16 2005, 08:00 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Jake, is the video available on dvd yet? I don't own a vhs/vcr.
scotty b |
Feb 16 2005, 08:02 PM
Yeah what Jake said too. I actually have a case in my destruction collection (parts that were to cool to toss) that some J.A. tried to pry apart and broke a jounal OFF because he forgot to take out that bolt.
415PB |
Feb 16 2005, 08:20 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Same thing happened to me and the advice I received from everyone was to check, check and check again for that one bolt and nut I was missing. Well I found it after looking for hourssssssssssss. Case came right apart after that. Good luck.
Jake Raby |
Feb 16 2005, 08:35 PM
All it takes is one....
Yes, Both my videos are now on DVD.... The DVD is 5 bucks more.. |
nsyr |
Feb 17 2005, 08:28 AM
Just want to say thanks, I did find that pesky bolt that was keeping it together. Took it out and it came right apart. Now back to the grind.......
Joe Ricard |
Feb 17 2005, 09:15 AM
So who can make up a picture of that hiding case nut. So Opera Guy can have a new AVATAR. (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif)
Jake Raby |
Feb 17 2005, 09:44 AM
Read my bio on my website... You'll seee that the first case I split when I was a kid was accomplished with a tree and a Tractor via a log chain...
Case tied to tree, case tied to tractor- Licketty split! We all have to learn- I forgot one nut and broke a case that time.. Never had an issue since! |
Joe Bob |
Feb 17 2005, 09:54 AM
Hey look who's back....Rod....under your avatar it should read..... "What is your malfunction, numbnutz..." Full Metal Jacket..... Back on subject....yeah when tearing down a dirty case, the nuts can be easy to miss. Once you get them all....it just falls apart. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:21 AM |
