Wilwood rotor question....., decent life out of them??? |
Mueller |
Feb 17 2005, 07:18 PM
I thought I read a few years back that compared to the factory and some of the higher end rotor manufactures that the Wilwoods have a tendancy of not lasting or holding up to abuse as well as the others...
anyone have 1st hand experiance with this ?? |
Dad Roberts |
Feb 18 2005, 11:38 AM
Member Group: Members Posts: 224 Joined: 1-January 03 From: Ontario,Ca. Member No.: 70 |
Mike.......A guy on Samba has them on a Type III. About all I got out of his post was that they are 4 piston? Someone has questioned him about size. I will follow it and let you know. Are these Wilwoods a bolt on ?? Type III calipers have the 3 inch spacing also. If so ....price?? I'm still thinking about putting my front calipers in place of the 914 rears I'm currently running. I do not need the Ebrake, haven't used one in years on this car. I need something for the front......nothing elaborate, just something that will work. Right now I have mainly fronts with what seems like very little rears. New 19 mm MC and new front calipers. Braided stainless hose, throughout. Pedal is good.....just unsure of performance.........Dad (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) .... carefully (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Mueller |
Feb 18 2005, 12:05 PM
Hey Pops (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
For my calipers I am using '86-'91 RX-7 Turbo calipers, they are dirt cheap 4-piston design....the bad news is the spacing is 158mm (6.222") centerline to centerline. I'm making bolt-on adapters for my application My rotors and hats are going to be from Wilwood.... Wilwood does have a brand new caliper out that is radial mount (mounting holes are 90° from the axis of the spindle compared to the stock mounting holes which are parallel to the spindle)...these are about $150 ea, but that price does not include the mounting bracket. I'm waiting to hook up with a Bug/Type III guy up in my area, once I do, I hope to be able to take some measurements and see what we can do for your car..... |
URY914 |
Feb 18 2005, 12:08 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,968 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is there a ALUMINUM caliper that will bolt up to the stock mounting holes? Those stock iron ones are killing me. |
Mueller |
Feb 18 2005, 12:21 PM
nope (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) at least I cannot find one..... I have an idea on how to mount the wilwood single dynalight (and keep your existing rotors), but it involves some cutting and welding, which I know you can handle (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) for a lightweight bolt-on (sorta) solution, you'd be looking at about $700 just for parts... |
Mark Henry |
Feb 18 2005, 12:35 PM
I know that the bug units are not as strong or long lasting as ghia callipers, don’t have a clue about a 914 app.
Hey Mike… finally figured out why you got 94mm Nickies….well, actually Charles phoned me last night for a chat. Nice, I would like to know what crank you're running and how much shim you’ll need under the jugs when you do your deck height. Might have a guy interested in a similar set up. |
URY914 |
Feb 18 2005, 01:12 PM
$700??? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) The pain ($) to gain (speed) ratio isn't right for that one. I'll stay with stock. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Paul |
Mueller |
Feb 18 2005, 01:40 PM
my engine parts should be shipping out to me early next week (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) I'm going with a 78mm counterweighted crank.....totally clueless about the shims for now (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Mark Henry |
Feb 18 2005, 02:04 PM
I'm getting around .140 lower pin, so a rough guesstamate would be a .250 shim.
It will make the engine a bit wide, but that's not a huge deal. Attached image(s) |
URY914 |
Feb 18 2005, 02:09 PM
lapuwali |
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Not that I know of, but there are lots of calipers you could use that are pretty light. You just need to have adapters made. Wilwood 4-pucks are as little as $100 each new, and they do have some that will work with the thin stock rotors. |
URY914 |
Feb 18 2005, 02:14 PM
I've looked at the Wilwoods and I've been waiting for Mueller to make some adapter/brackets. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) I just need to find one and figure out how to do it meself. Oh well. Paul |
Mueller |
Feb 18 2005, 02:16 PM
get my PM ??? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
URY914 |
Feb 18 2005, 02:31 PM
I guess I spoke too soon. I got your PM and replied. I've looked at the drawing of the Dynalight on thier website, but haven't spent a lot of time trying to figure it out. Paul |
Mark Henry |
Feb 18 2005, 02:33 PM
Paul (IMG:http://www.914world.com/bbs2/html/emoticons/pissoff.gif) this is my hijack (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Mike, the cimas are a good piston and with the offset pin the piston rocks a lot more gentle when it hits TDC. I think it's a cool (and cheaper) combo. I almost did this, with 93's bored out to 94mm, before I went for the 103's. end of hijack..... |
URY914 |
Feb 18 2005, 02:44 PM
They used to hijack planes to Cuba, now you hijack threads to Canada.
What is the world coming to... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) P |
Mueller |
Feb 18 2005, 02:51 PM
90% of my SPAM is related to the f'n drug companies up in Canada..what's up with that??? (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif)
i'm really excited about my new motor....I have a stupid grin on my face just from driving my 1.8 914.....my poor 3.6 911* has been getting totally neglected due to the 914... *I took it around the block over the weekend.....spun the cold 255mm wide tires about 75 feet going up the street (IMG:http://www.914world.com/bbs2/html/emoticons/MDB2.gif) the wife just shakes her head at me when I walk back into the house.... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Mark Henry |
Feb 18 2005, 03:07 PM
Paul…Don’t mess with a Canadian…I’ll put weights in your car! Drugs are about half price from Canada, big business. US drug companies hate it and are lobbying to stop it. How can they gouge (more like butt-fuch) the US public with cheap Canadian drugs on the market? Whooooppps…Canadian hijacker at work…..Back off eh, I’m not kidding about the weights. |
cha914 |
Feb 18 2005, 03:38 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Damn! I just checked and those 4piston RX7 calipers can be had for 65 bucks each used!
So, what about a bolt on kit for these? (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) I know there is a vw company (www.franklinsvwwerks.com) that is using these for a brake upgrade kit on a bay window bus, here is a pic, but it doesn't show how they are mounting it: (IMG:http://www.franklinsvwwerks.com/images-sm/sm-ultralight-baywindow-kit-2-home.jpg) also, these guys do some pretty cool porsche hubs/brake kits for the T1 crowd: http://www.vdubcustoms.com/Wedo/pbrakes.htm Tony |
Dad Roberts |
Feb 18 2005, 03:43 PM
James!!!!...( lapuwali )...I new you would find me (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif). NOW.....I recognize your screen name. Glad to see I've got you workin over here, too. You say Wilwood has some for our thin rotors, do they also fit our brackets? Mike....James can probably help us with the bug/Type III questions. He has been very helpful to me. I think he's up your way, too................Dad (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 02:17 PM |
