> What's the conversion for..., This is a hard one...
iiibdsiil
post Feb 17 2005, 08:27 PM
Needs Door Locks
PSI to the compression ratio?
Replies(1 - 11)
Jake Raby
post Feb 17 2005, 08:28 PM
Engine Surgeon
Their really isn't one...
The cam and so many other factors effect cylinder filling and that effects cranking compression...
redshift
post Feb 17 2005, 08:35 PM
Bless the Hell out of you!
Happy Belated Birthday ANYHOW!
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Didn't see you around.
M
iiibdsiil
post Feb 17 2005, 08:36 PM
Needs Door Locks
Miles, thank you sir.
Jake,
You are killing me here. I guess that is the right answer though, I'm just not happy about it.
Jake Raby
post Feb 17 2005, 08:39 PM
Engine Surgeon
Pop off a head, measure the deck and cc the chamber...
Thats the only for sure way to know...
TimT
retired
Rough work around,
say 8.5:1CR
8.5*14.7=124.9psi
so you could take psi and divide by 14.7 to tell you a rough CR
if that what your looking for..
Like Jake says to many other variables. Cam Timing,profile etc.
iiibdsiil
post Feb 17 2005, 08:49 PM
Needs Door Locks
Thanks guys. Explains why I couldn't get a straight answer on google.
Jake Raby
post Feb 17 2005, 09:18 PM
Engine Surgeon
Elevation effects air density and air density effects cranking PSI....
So someone in Florida can compression test their engine, drive it to Colorado and re-test it and get two drastic different readings... The higher the altitude the LESS PSI you will see.
I set engines that are going to High Altitude 20% higher than normal as an average number.....
iiibdsiil
post Feb 17 2005, 09:38 PM
Needs Door Locks
That makes sense. I never thought about it being that deep. Makes perfect sense.
john rogers
post Feb 17 2005, 10:19 PM
The answer about cam overlap and the affects on compression is spot on. At one of our vintage races a guy from AZ has a 1969 Z28 and it cranks over like there are no heads on it. I asked him what the c/r was and he said 13:1 but with the cam overlap he could maybe get 100# when doing a compression test! Boy it sure ran good though once it fired up!
Gint
post Feb 17 2005, 11:11 PM
Mike Ginter
And 20% is just about the right number for the difference between sea level and Denver at 5K altitude.
Jake Raby
post Feb 18 2005, 01:25 AM
Engine Surgeon
You got it....
When I say that i build engines for the application- Its not BS (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
- Lo-Fi Version Time is now: 13th July 2025 - 04:53 PM
