weber question |
weber question |
nickg |
Feb 17 2005, 09:32 PM
Senior Member Group: Members Posts: 501 Joined: 30-August 04 From: franklin, nj Member No.: 2,652 |
i have a set of neew looking webers from my 914-6. my question is are they all safety wired? it says on the side idt, are the rebuild kits the same as an ida?(ther is a set on ebay that's why i ask)
bwilless |
Feb 17 2005, 09:48 PM
Member Group: Members Posts: 156 Joined: 24-January 03 From: Tempe, AZ Member No.: 192 |
I think that the only difference between IDA's and IDT's is some smog type things. I think you can actually modify the IDT's to basically become IDA's. Experts please correct me if I'm wrong.
ArtechnikA |
Feb 18 2005, 06:14 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
IIRC the only parts wired on a /6 Weber are the venturii retaining grub screws.
what do you see that is wired ? |
nickg |
Feb 18 2005, 09:47 AM
i will take a picture and post it tonight
bob |
Feb 18 2005, 10:32 AM
Member Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None |
I think Rich is right the only thing wired is the venturi retaining screws.
The Throttle Stops are different as well as the mixture screws. you can use either throttle piece on either carb, but you have to use the correct mixture screws. (there is a 'step' on the IDT, while the IDA is tapered) |
Lo-Fi Version | Time is now: 7th June 2024 - 03:34 PM |
