Seat belt locks up when pulling it out |
dangerranger01 |
May 1 2015, 07:39 PM
Member Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
My driver's seat belt in my '73 locks up every few inches as I pull it out (IMG:style_emoticons/default/dry.gif) . Then I have to pull it out another few inches before locking up again. Now repeat (IMG:style_emoticons/default/bs.gif) . Needless to say, it takes about 2minutes to buckle up when I go out for a drive. Passenger's side is fine.
Anyone experience this problem and know of a fix (or have a good belt one for sale? (IMG:style_emoticons/default/poke.gif) )? It is kind of a pain in the butt everytime I go out with it... Thanks! |
ripper911 |
May 1 2015, 07:49 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I've heard that if you get it all of the way out and use scotchbrite on the webbing it will help.
I still need to do that. (IMG:style_emoticons/default/dry.gif) |
Dave_Darling |
May 1 2015, 08:12 PM
Pull it all the way out and use a binder clip or two to keep it extended. Clean it with mild soap and water, rinse. let dry. It should work better, though maybe not perfect. Scotchguard can evidently help, too.
--DD |
GeorgeRud |
May 1 2015, 08:50 PM
A re webbing service would be a great addition. As these belts are at least 39 years old now, having new, flexible webbing would be nice. Cleaning and lubricating the mechanism would also help!
steuspeed |
May 1 2015, 09:24 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
IIRC taking apart the mechanism is not recommended. Very difficult to put back together.
Cuda911 |
May 1 2015, 09:42 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
I had the exact same problem. I pulled the belt all the way out to it's farthest extension, then sprayed the roller mechanism with silicone lube using one of those thin straw-like spray extenders. Works like new!!!
bdstone914 |
May 2 2015, 07:05 AM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You can remove the thin side cover to clean and inspect the internal parts. Dont try to take off the side cover with the spring.
You can buy the webbing online. I used to take them to an upulustry shop that would resew the end parts. Just not DOT certified. |
SKL1 |
May 2 2015, 07:08 AM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I had seatbeltplanet redo the belts in my '73. Look and work like new and reasonable price.
GeorgeRud |
May 2 2015, 07:18 AM
Thanks for the link, I'll give seatbelt planet a look. I'd love to get some new webbing installed on my retractor belts.
JmuRiz |
May 2 2015, 09:14 AM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Good info, I'm sure most of our belts need refurbished.
somd914 |
May 2 2015, 01:56 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Mine did the same and opted for the SeatPlanet fix. The ones I bought fit the factory receiver so still look stock.
dangerranger01 |
May 2 2015, 02:42 PM
Maaaad thanks guys. I'll try cleaning them and also lubing up the rollers...hopefully it helps out.
Porsche930dude |
May 2 2015, 05:48 PM
Member Group: Members Posts: 399 Joined: 25-November 11 From: Vestal NY Member No.: 13,819 Region Association: None |
I found that changing the orientation of how it mounts helps. loosten the bolt and try it in different positions and make sure the belt is pulling straight out.
Mblizzard |
May 2 2015, 08:31 PM
After cleaning the belts spray with Scotch Guard. Keeps them sliding.
dangerranger01 |
May 3 2015, 12:19 AM
Is this the scotchguard y'all are talking about?
http://www.walmart.com/ip/Scotchgard-Fabri...-10-oz/13281231 Do I spray that on both sides of the belt after cleaning?? My webbing seems soft and good/usable so hopefully I can get away without a rebuilt unit. |
Mblizzard |
May 3 2015, 05:44 AM
Is this the scotchguard y'all are talking about? http://www.walmart.com/ip/Scotchgard-Fabri...-10-oz/13281231 Do I spray that on both sides of the belt after cleaning?? My webbing seems soft and good/usable so hopefully I can get away without a rebuilt unit. That's it. |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:56 AM |
