Reinstalling fuel injection, How long |
cal914 |
May 3 2015, 02:46 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
When reinstalling injection from carbs how long does it generally take assuming you have all the parts
Thanks Brian |
Mike Bellis |
May 3 2015, 02:50 PM
That is relative to your skill level. Plan on a weekend to be safe.
cal914 |
May 3 2015, 02:57 PM
type47 |
May 3 2015, 02:58 PM
3 hours
GeorgeRud |
May 3 2015, 03:18 PM
Also depends how many changes were made to the fuel pump circuit. The injection system is pretty much a pretty simple system in comparison to some of today's systems.
DRPHIL914 |
May 4 2015, 06:30 AM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I've never had carbs but when I first had the car I pulled everything off to replace all the seals and gaskets to eliminate vac leaks. That included new plenum throttle body runners injectors wiring vac and fuel lines and I think that took about 3 Hours. So depnds on your experience and knowledge. I can't imagine it would take more than that. Just remember you need a different fuel pump too.
Tbrown4x4 |
May 4 2015, 06:48 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
If the injection was taken off and replaced with carbs, there could be diagnostic time to figure out why it was removed in the first place.
Dave_Darling |
May 4 2015, 08:42 AM
And, of course, if the cam was changed, the sky is the limit...
--DD |
DRPHIL914 |
May 4 2015, 09:50 AM
If the injection was taken off and replaced with carbs, there could be diagnostic time to figure out why it was removed in the first place. And, of course, if the cam was changed, the sky is the limit... --DD (IMG:style_emoticons/default/agree.gif) make sure cam was not changed for carbs; ** some tuning will be necessary in most cases |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:04 AM |
