Remove flappers inside engine cowl? |
Bill's Racing 914 |
May 3 2015, 04:45 PM
Member Group: Members Posts: 61 Joined: 2-March 14 From: Southern California Member No.: 17,064 Region Association: None |
I have a 1.7L that I am building up to race EP in VARA. Should I remove the two flappers inside the front cooling cowling or leave them there? With them open fully, the oil cooler looks like it is covered up and will get no air.... (IMG:style_emoticons/default/huh.gif)
brant |
May 3 2015, 10:30 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
We screw them full open to to the cooler with sheetmetal screws on -4 race motors
SirAndy |
May 4 2015, 10:43 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just to clarify, the "full open to the oil cooler" position for the flaps is the default mode when the thermostat is disconnected and the passenger side flap will be DOWN and flat over the cooler.
It may look like it's blocking the cooler but in that position it actually forces the most air through the cooler. If you remove or change the position of the flaps the cooler won't get full air. (IMG:style_emoticons/default/smash.gif) |
SirAndy |
May 4 2015, 10:48 AM
Below is a pic of the flaps in the default position when there is NO thermostat connected.
This is the full cooling position and as you can see the passenger side flap looks like its blocking the cooler but it actually directs the maximum air down and through the cooler. If you want full cooling at all times, that is the position you want. (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-179-1430758125.1.jpg) |
ChrisFoley |
May 4 2015, 10:59 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
remove the flaps and the stock cooler.
SirAndy |
May 4 2015, 11:20 AM
remove the flaps and the stock cooler. (IMG:style_emoticons/default/agree.gif) or do that ... (IMG:style_emoticons/default/biggrin.gif) |
Bill's Racing 914 |
May 5 2015, 04:17 PM
Thanks everyone for the quickresponse! excellent solutions with and without the stock oil cooler....Bill (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 01:10 AM |
