Antenna mounting location and cable routing |
jack20 |
May 4 2015, 01:17 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
My car previously had an antenna mounted on the cowl. I filled the hole prior to paint and bought a Hirschman antenna to mount on the fender, the proper location. I saw a location diagram on World some time back but neglected to bookmark it. Does anyone recall seeing it?
I also need to know where to drill to route the cable through the inner fender. Thanks in advance. Jack |
SirAndy |
May 4 2015, 03:58 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If i recall correctly they were all dealer installed, i'm not sure there is a factory correct location or if there ever was one "correct" template for the install.
(IMG:style_emoticons/default/dry.gif) |
Mike Bellis |
May 4 2015, 04:11 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
From Jeff Bowlsby
(IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-10496-1430777463.1.jpg) |
Mike Bellis |
May 4 2015, 04:12 PM
Mike Bellis |
May 4 2015, 04:14 PM
jack20 |
May 4 2015, 04:37 PM
Thanks so much!! This is exactly what i was looking for.
Now Ill try and locate the rubber plug in the fender well. Jack |
worn |
May 4 2015, 10:10 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
From Jeff Bowlsby Well that looks like at least factory approved as a spot. I kinda like the retractable antenna in my 911. But don't seem to see them in the 914s. Originals more budget oriented? Or is it just gauche? I can't hear it much anyway but still. They don't snap off if they are in the down position. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:20 PM |
