My contribution to the flat bed thread |
mepstein |
May 4 2015, 08:26 PM
914-6 GT in waiting Group: Members Posts: 19,308 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Attached thumbnail(s) |
76-914 |
May 4 2015, 09:10 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What happened? Post your pic in the thread. Here it is http://www.914world.com/bbs2/index.php?sho...=175444&hl=
Cairo94507 |
Michael Group: Members Posts: 9,815 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Oh no! All right spill the story already. (IMG:style_emoticons/default/beer3.gif)
mepstein |
May 5 2015, 05:31 AM
2 miles from my house, on my way to work, the engine cuts out. I was accelerating in third at about 3K and it just stalled. Coasted to a stop and it wouldn't start again. Motor turns over but doesn't fire. Towed it to my local mechanic and put it into an unused garage. I didn't trust the tow driver to be able to navigate up my driveway backwards and drop it in the garage. My local guy can but this guy - no. I will stop by this week and see what's up. I didn't see anything obvious while i was waiting for the tow and there is gas in the tank. Saving grace is my insurance covers the tow.
After driving 200+ miles at hershey without a hiccup, I was surprised. |
JoeDees |
May 5 2015, 08:14 AM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
I bet it's something dumb like a wire coming unplugged that will make you laugh when you find it.
flipb |
May 5 2015, 11:51 AM
Senior Member Group: Members Posts: 1,725 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
I bet it's something dumb like a wire coming unplugged that will make you laugh when you find it. (IMG:style_emoticons/default/agree.gif) My money's on fuel pump. |
VaccaRabite |
May 5 2015, 11:56 AM
En Garde! Group: Admin Posts: 13,459 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Yeah, somehting electrical.
Either the fule pump wire came off, or the condenser wire, or a fuse, or somehting of that ilk. Zach |
Java2570 |
May 5 2015, 12:01 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I had this very issue happen to me when I took a corner quickly....it just stopped running. Luckily, I got it restarted and got back home with no further incident. However, the next day...it happened again and I couldn't get it restarted. I was too dumb to realize that the fuel pump wasn't cycling when I turned the key and that the fuse came unseated on the relay board. I had my brother help me push the car 1/2 mile back to my house. At that point, I thought of the fuse and checked the relay board. After reseating the fuse, I was able to start the car and drive into my garage! Man, did I feel like an idiot!!
mepstein |
May 5 2015, 12:03 PM
I do hear the pump cycle for a second or 2 when I turn the key.
ThePaintedMan |
May 5 2015, 12:19 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
If fuel pump is cycling, then that should be a sign that it's *probably* okay. They usually either work, or do not.
Next try looking for spark while having someone turn it over. Take a plug wire off and hold it close to the case or something metal. See if you have any spark. If not, pull the dizzy cap off. I've seen caps suddenly vibrate off as well as rotor buttons. |
mepstein |
May 5 2015, 12:44 PM
I will try to get to it this weekend. Thanks guys!
9won4 |
May 5 2015, 02:00 PM
Newbie Group: Members Posts: 47 Joined: 2-October 13 From: Las Vegas Member No.: 16,465 Region Association: Southwest Region |
somd914 |
May 5 2015, 03:00 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
D-Jet? If so, check CHT wire - mine broke, engine bucked and that was it. Attempting to re-start, had spark, but it was so rich there was no sign of ignition.
jeffdon |
May 5 2015, 03:22 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Busted Crankshaft, July 2014.
Chris H. |
May 5 2015, 08:17 PM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Well, at least it happened close to home and not during the Hershey trip. No bad noises = probably something simple. Should be fixed up good in no time.
Speaking of bad noises...busted crankshaft? I bet that was some racket... |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:33 PM |
