WEVO needs your help! |
Jeroen |
Feb 18 2005, 09:00 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Well, it's not as dramatic as it sounds (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Can anyone measure the boltspacing on the transmission mounts? Center to center. Measurement preferred in mm (not inches) I've measured mine, but I feel kinda nervous about messing up a production run because I measured wrong (you know I'm dangerous with tools) This is so we can get these for our 914 too (the are available as 911 engine mounts, but the bolt spacing is a little different from the 914 tranny mounts) Attached image(s) |
TheCabinetmaker |
Feb 18 2005, 09:09 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
My old eyes see 87sillymeters.
ClayPerrine |
Feb 18 2005, 09:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I found that the sport mounts won't fit correctly... but there is a solution. Just take a Big F'in Hammer and whack the front of the mounts that are welded to the car. After about 2 whacks, the mounts fit fine...... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Jeroen |
Feb 18 2005, 10:22 PM
That's exactly why I'm asking for MEASUREMENTS WEVO will build these mounts to fit the 914 'cmon guys... |
Mueller |
Feb 18 2005, 10:26 PM
I measure 96mm center to center
9.5mm thru holes overall mount length is 115.70mm |
IronHillRestorations |
Feb 19 2005, 09:52 AM
I. I. R. C. Group: Members Posts: 6,725 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yea, I use the monster HD C clamp and sqeeze the "ears" together. Best I remember is there's about 6mm difference between the club sport engine mounts and the 914 tranny mounts. |
wilchek |
Feb 19 2005, 02:24 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
I measured around 96mm also, but that was with the piece on the car could be 95 or 97.
TMorr |
Feb 19 2005, 06:21 PM
Tracey of Windrush Group: Members Posts: 85 Joined: 28-January 03 From: San Carlos, CA USA Member No.: 205 |
Thanks you guys.
We will have a batch of these shortly. The holes will in fact be slotted to allow for some alignment front to rear, which we have seen is appropriate for the pre-load free installation of the transmission mounts. Regards Hayden PTB Tracey |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:37 PM |
