Bilstein rear setting |
lsintampa |
May 7 2015, 12:12 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0
Stock rear springs. Suggested starting cir-clip position for Bilstein's HD? Nothing special - just a 2.0 - not being tracked, raced, or even driven - except to shows or casual drives on occasion. thanks, Len |
sbsix |
May 7 2015, 12:25 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 451 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Len, I run my 914-6 with 100 lb rear springs and the Bilsteins at the 3rd groove up from the bottom for a stock ride height.
r_towle |
May 7 2015, 12:38 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bottom, ride low
Porschef |
May 7 2015, 03:21 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
I just installed a good used pair over the past weekend. I matched them up with the KYB's that were in there already, and gave me the height I wanted. This turned put to be the second groove. When reinstalled, I saw no difference in the ride height, so I'm gonna assume that worked.
I just cruise for the most part, no AX. |
nine9three |
May 7 2015, 03:31 PM
Member Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest |
I also have the adjustable perch Bilsteins with the 100lb Weltmeister springs. I am one up from the bottom or second position. The car rides really rough. I was thinking that maybe I was bottoming the shocks out but my wheel to fender lip is higher than some so I guess it just rides rough? It looks good though.
Dave_Darling |
May 7 2015, 04:22 PM
I suggest starting in the middle. If it's too low, then go halfway from there to the top. If it's too high, go halfway from there to the bottom. Check each time, and go in steps half the size of the previous one.
...I guess that's the software engineer in me, recommending a binary search for spring perch position... --DD |
mepstein |
May 7 2015, 04:47 PM
914-6 GT in waiting Group: Members Posts: 19,283 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I also have the adjustable perch Bilsteins with the 100lb Weltmeister springs. I am one up from the bottom or second position. The car rides really rough. I was thinking that maybe I was bottoming the shocks out but my wheel to fender lip is higher than some so I guess it just rides rough? It looks good though. Check your tire pressure. The guy who installed mine pumped them up to 36psi. I dropped them down to 28 and I like the ride. 195x65x15 |
saigon71 |
May 7 2015, 05:46 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Just checked mine...5th groove up from the bottom.
Running stock (possibly factory) springs. Like Joe, I did my best to match the spring tension from the old shocks. |
lsintampa |
May 7 2015, 06:51 PM
Hey all,
I think I'll try either 2nd or third - go from there. Maybe third position to start and go from there. Thanks! |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:51 PM |
