oil temp |
oil temp |
RonnieJ |
May 8 2015, 06:56 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
I drove to work this morning which is a twelve mile stop and go muliple stop lights drive and my oil temp was 200. By the way the drive takes about 25 minutes. Is that to high for a drive like that?
Last930 |
May 8 2015, 08:20 AM
Member Group: Members Posts: 60 Joined: 15-September 14 From: Illinois Member No.: 17,905 Region Association: Upper MidWest |
I drove to work this morning which is a twelve mile stop and go muliple stop lights drive and my oil temp was 200. By the way the drive takes about 25 minutes. Is that to high for a drive like that? The needle on my oil temp gauge barely moves off the peg on a drive like that; I'm not sure if something's not working or it just runs cool. Optimum oil temp should be around 180 in a perfect world. If your drive is stop and go in traffic I'd say 200 is fine. |
mrholland2 |
May 8 2015, 08:27 AM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
I drove to work this morning which is a twelve mile stop and go muliple stop lights drive and my oil temp was 200. By the way the drive takes about 25 minutes. Is that to high for a drive like that? I would be concerned that the cooling flaps aren't opening to the cooling position ever. . . or the other guy that responded has cooling flaps that are always in the cooling position. . or both |
Ferg |
May 8 2015, 08:34 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Sounds normal to me.
boxsterfan |
May 8 2015, 09:29 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
200 is pretty normal. Assuming cooling flaps working properly, nothing blocking the fan, no crud/dirt on the stock oil cooler, fins on the heads are fairly clean, timing and valves are in spec then the only other thing to start looking at is the oil pressure relief valve.
Dave_Darling |
May 8 2015, 10:00 AM
212F is a perfectly fine temp. 180F is a bit on the cool side; it will take the water in your oil longer to outgas at that temp.
--DD |
RonnieJ |
May 8 2015, 10:10 AM
Thanks all
Lo-Fi Version | Time is now: 23rd May 2024 - 01:57 AM |
