removing my relay board cover |
914Next |
May 12 2015, 06:15 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
I know this is so basic but can someone tell me how to remove the relay board cover on my '73? After removing the top nut, I thought it would lift off but it does not. It feels like it would lift off on the side facing the bumper but still seems to be attached on the back side. Don't want to crack or break it by just trying to yank it off.
Steve |
Shadowfax |
May 12 2015, 06:22 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
It should lift off easily. Maybe it is getting caught on one of the harness connectors?
cary |
May 12 2015, 06:28 AM
Should roll straight back towards the rear of the car.
Kind of depends on what voltage regulator you have. The newer ones create a pretty tight fit against the front portion of the cover. I would say to remove the voltage regulator. Which makes it a little easier. But doing so too much can cause issues with the tar on the bottom of the regulator board. |
VaccaRabite |
May 12 2015, 06:58 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have always pulled the VR. At least on mine it would be VERY tough to get the cover off without the VR being removed.
Zach |
914Next |
May 12 2015, 07:24 AM
I have always pulled the VR. At least on mine it would be VERY tough to get the cover off without the VR being removed. Zach Thanks guys. Actually, now that I look at it, it seems that it would be almost impossible to lift the relay cover off without removing the voltage regulator. There just isn't enough room to slip the cover between the top of the VR and the engine pad. I have the original VR on the car. everything is stock. Is the VR a simple unscrew the two screws and remove? |
rhodyguy |
May 12 2015, 07:34 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Yes.
914Next |
May 12 2015, 09:39 AM
thx
cary |
May 12 2015, 10:42 AM
Don't push hard putting it back in.
rhodyguy |
May 12 2015, 10:47 AM
Clean the ground post forward and below the relay board while you're in there...
michael7810 |
May 12 2015, 12:39 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I have to remove the screw that holds the relay board on the rails and slide the board inward to allow the cover to lift off.
Lo-Fi Version | Time is now: 10th June 2024 - 11:02 PM |
