No Spark. 1974 1.8 L-Jet. Pertronix, What to check? |
tach |
May 15 2015, 09:09 PM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
1974 1.8 L-Jet. Pertronix 1847V. No spark when cranking over the engine. I do get one spark on a plug when I turn the key switch off and the rotor is in the correct position to spark that particular plug. What to check?
New cap and rotor. Bosch blue coil. Update. It looks like the pertonix sensor is to high on the distributor mounting plate. |
TheCabinetmaker |
May 16 2015, 04:58 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Your missing something in your distributor. Points and condenser.
budk |
May 16 2015, 05:11 AM
Yes! It's a Bumblebee! Group: Members Posts: 678 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
TheCabinetmaker |
May 16 2015, 06:05 AM
Well, no. I did not, but you missed my attempt at humor! His pertronics is probably toast. He needs to install points and see if it runs.
Old Yella |
May 16 2015, 01:04 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
rotor maybe---or timing is just out
rhodyguy |
May 16 2015, 01:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Does your timing light flash when you test each plug wire while cranking?
sportlicherFahrer |
May 16 2015, 03:08 PM
Nothing to see here. Group: Members Posts: 1,084 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Had the same issue a couple years ago. Every time it sporadically sparked it sounded like I was shooting ducks in my garage. Neighbors LOVED it! (IMG:style_emoticons/default/dry.gif) Failing module from what I could tell. Ended up putting the good ol' mechanical stuff back in and drove down the road fine after 5 minutes of reinstalling and setting timing.
pilothyer |
May 16 2015, 03:15 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I have found one of the most important things you need when converting from mechanical points to a Pertronics............A SPARE PERTRONICS SET-UP.
timothy_nd28 |
May 16 2015, 06:57 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I have found one of the most important things you need when converting from mechanical points to a Pertronics............A SPARE PERTRONICS SET-UP. (IMG:style_emoticons/default/agree.gif) |
turk22 |
May 16 2015, 08:01 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
Make sure the petronix magnet is seated correctly on the rotor. I had a similar problem shortly after original install, it was that the magnet was not fully seated correctly on the rotor.
76-914 |
May 17 2015, 08:21 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
They have a trouble shooting guide on their website if you want to check the unit. I've had one set in for 5+ years w/o any problems.
Lo-Fi Version | Time is now: 28th May 2024 - 03:14 PM |
