20mm master cylinder, what from? will it work? |
jgiroux67 |
Feb 20 2005, 06:42 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
What model of 911 did a 20mm master cylinder come off of? Will it work on my 914 with A calipers?
jgiroux67 |
Feb 20 2005, 06:44 PM
here's a picture
Attached thumbnail(s) |
TimT |
Feb 20 2005, 06:48 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
911S
davep |
Feb 20 2005, 06:52 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The proper 20mm did indeed come from the 911S and also from some 911E with the hydropneumatic stuts. Started in 1969.
That is not the correct master though, it is for a boosted car. The proper 20 looks identical to the 17 and 19 except for the 20 cast into it. Yes, a 20 should work fine with the 'S' or 'A' calipers, especially if you use the 914/6 rear. |
jgiroux67 |
Feb 20 2005, 07:03 PM
So what is the master cylinder that is in the picture and would that one work?
jgiroux67 |
Feb 20 2005, 07:24 PM
The guy that I might be getting it from told me that it is from a '80 euro 911sc. Im assuming that the fittings are the same?
Aaron Cox |
Feb 20 2005, 08:14 PM
its designed to work with a power brake booster (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
jgiroux67 |
Feb 20 2005, 09:24 PM
Would it work without the brake booster?
Qarl |
Feb 20 2005, 09:36 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
no
jgiroux67 |
Feb 20 2005, 09:40 PM
Damn it, so a regular 19mm 911 master cylinder is realy the only way to go if your using A calipers?
914GT |
Feb 20 2005, 09:47 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
As far as I know, yes. You know, even if the 20mm worked your brake pedal effort would be harder - assuming stock calipers. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:51 AM |
