Fuel Pump Question, Suggested Fuel Pump Brand and source |
forrestkhaag |
May 19 2015, 07:03 PM
Does anyone have a tried and true suggestion for a brand and source for a fuel pump to be located in the vicinity of the original pump location for my conversion to carbs?
I have dual 40's fitted to a 2.2L 4 and have routed a 3/8" SS line from the tank/tunnel to the firewall in the engine compartment. Thanks for the input. (IMG:style_emoticons/default/beerchug.gif) |
screenguy914 |
May 19 2015, 07:27 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Does anyone have a tried and true suggestion for a brand and source for a fuel pump to be located in the vicinity of the original pump location for my conversion to carbs? I have dual 40's fitted to a 2.2L 4 and have routed a 3/8" SS line from the tank/tunnel to the firewall in the engine compartment. Thanks for the input. (IMG:style_emoticons/default/beerchug.gif) What are the pressure requirements? |
Kansas 914 |
May 19 2015, 07:46 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
i like the Carter Rotary. Self regulated for carbs and very quiet.
Carotor http://carterfuelsystems.com/fuelpumps/universal_fp.php |
patssle |
May 19 2015, 08:35 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Running that Carter on my /6 and previous ran it on my /4 as well. I don't see the point of having a high pressure fuel system if it can be avoided.
larryM |
May 19 2015, 08:37 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
simple - just get a Facet pump from any of 1000 suppliers online - perfect for carbs - Facet pumps also get a pressure regulator to keep the psi around 3 |
forrestkhaag |
May 21 2015, 07:35 PM
Thanks to all for the info / I went with the Carter pump after hearing a few reports on reliability and relative quietness from folks that are currently running that pump without incident / although noise is not an issue with my 914 - which is purposefully missing firewall padding, all heater and ventilation garb under the cowl, back pad sound deadening materials, etc. etc.
Lo-Fi Version | Time is now: 31st May 2024 - 07:40 PM |
