mike_the_man |
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 ![]() |
What does everybody do with the interior light, etc? I'm assuming just remove it. I think that I have a few other wires running around behind the back pad from the PO as well. Whats the best procedure for doing this? What type of glue is good to use? Lets hear some tips, and any pics would be appreciated as well.
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
I'm replacing mine with lights built into a rearview mirror.
mike_the_man |
Good idea. I was thinking about that too. What sort of mirror are you using? I know that Mustang convertibles have a mirror like that.
SteveSr |
Member ![]() ![]() Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 ![]() |
Same here,using the one out of the doner car i took the V6 from ...1991 chevy Corsica. SteveSr |
horizontally-opposed |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,435 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None ![]() ![]() |
I wonder if (a more effective one) could be worked into the targa bar front pad. The trick would be making it look good, maybe tucked in at an angle on the pad's lower surface, back near the glass?
pete |
mike_the_man |
Good idea Pete, I hadn't thought of that. I'll have to have a look. I bet something could be done.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
My truck has flush mounted "directional" lights (you can move them) mounted in the overhead console. Some of these mounted in the targa pad (under the targa bar, not in front of it) would be trick. Show us some pics..
B |
mike_the_man |
I like it Brad. Should be able to find some lights like that at the local pick a part.
Long time no see, Brad. How are you doing? Busy as always, I'm sure. |
xsboost90 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 ![]() |
what about making a center piece made of spray foam, shaping it, installing the light and then gluing it on, and carpeting over that?
Lo-Fi Version | Time is now: 17th June 2024 - 01:03 PM |
