> Cold start vale, Test for stuck open.
DavidSweden
post Jun 16 2015, 02:54 PM
Can anyone tell how to test if the cold start valve is stuck open?
Thanks
Replies(1 - 8)
pilothyer
post Jun 16 2015, 06:44 PM
QUOTE(DavidSweden @ Jun 16 2015, 03:54 PM) *
Thanks
The cold start valve should only operate when the ambient temp is very cold, and when the starter is engaged. Remove the valve and point it into a clear jar turn the switch on and see if fuel comes out when the fuel loop is pressurized .......if it does it is a leaker. If you want to test it for operation bypass the thermo switch and give it ground.....when the starter is engaged it should spray fuel into the jar.
worn
post Jun 17 2015, 09:05 AM
QUOTE(DavidSweden @ Jun 16 2015, 01:54 PM) *
Thanks
In summer the plenum will be full of gas if it is stuck open very much. You can pull the air filter and look in.
r_towle
post Jun 17 2015, 09:41 AM
Custom Member
get a piece of brake tubing the correct diameter and pull both fuel lines off the valve, route the fuel around it with the tubing in the middle of the two hoses.
Also unplug the electrics on the valve.
They do leak and dribble raw fuel into the intake when old.
rich
Ian Stott
post Jun 17 2015, 04:38 PM
Any chance you could post a picture of that, I need to do that.
Ian Stott
Moncton
Canada
r_towle
post Jun 17 2015, 07:51 PM
Custom Member
QUOTE(Ian Stott @ Jun 17 2015, 06:38 PM) *
Ian Stott
Moncton
Canada
No pics but it's simple
The cold start valve is shaped like a t splitter
Fuel comes in one side and goes out the other.
So. Pull off both fuel lines and put a piece of tubing inside both ends to connect them together....now no fuel will go through the cold start injector
DavidSweden
post Jun 18 2015, 10:20 AM
QUOTE(r_towle @ Jun 17 2015, 05:51 PM) *
Ian Stott
Moncton
Canada
I may be mistaken but isnt the cold valve #3 on the pic. Only one input?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1434644451.1.jpg)
pilothyer
post Jun 18 2015, 01:25 PM
The L-Jet has two ports, Maybe he thought you had L-Jet Fuel Injection.
r_towle
post Jun 18 2015, 01:57 PM
Custom Member
ok, so its one port.
remove the t-connector in the fuel line.
OR, just simple plug it.
The objective is to stop putting any fuel at all into that injector.
rich
- Lo-Fi Version Time is now: 3rd March 2026 - 06:37 AM
