| jim_hoyland |
Jun 22 2015, 07:46 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,079 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Thanks to Socalandy; I have a replacement VIN sticker for the driver side door jamb. The original sticker got mangled and needs to be replaced; it's stuck on the metal pretty good. What's the best way to loosen the adhesive so the sticker can be peeled back and removed ?
| Mike Bellis |
Jun 22 2015, 07:54 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Hair dryer or heat gun. Don't get it too hot!
| jim_hoyland |
Jun 22 2015, 07:56 PM
| Mike Bellis |
Jun 22 2015, 08:17 PM
When the paint bubbles, that's too hot.
You want it warm but not to hot to touch. A finger nail or plastic scraper will help too. |
| toolguy |
Jun 22 2015, 08:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
Use a Popsicle stick or better yet a doctors tongue depressor. . sharpen the end
so it is sharp, like a chisel blade. . use this to ease off the old sticker as it won't hurt the paint. . It's a go slow project, and a hair dryer will give you the right amount of heat without overheating the paint. . |
| jim_hoyland |
Jun 22 2015, 08:37 PM
Thanks.
| EdwardBlume |
Jun 22 2015, 10:09 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I've found goo be gone to work well in certain applications of the sticky kind...
| MJHanna |
Jun 23 2015, 05:56 AM
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
Don't laugh but they make plastic razer blades. They work well taking off , clear bra's and other stuff on paint with out damging the paint. Use with the heat and
alcohol. |
| jim_hoyland |
Jun 23 2015, 06:10 AM
Update: Used the heat gun with a popcycle stick that was filed to look like a chisel. Took all of 5 minutes to remove the sticker. Then I used Terpentine to remove the remaining adhesive. Worked out great (IMG:style_emoticons/default/smile.gif)
And under the old VIN was the original color of the car...... |
Lo-Fi Version | Time is now: 7th June 2026 - 09:10 AM |
