> Installed, floor pan deflectors
cpavlenko
post Jun 23 2015, 12:31 PM
Wasn't to bad, would've been much easier with a 4 post lift. I only had drive up ramps and jack stands. All went well. Attached Image Attached Image
Replies(1 - 19)
JStroud
post Jun 23 2015, 12:43 PM
Looks good, next upgrade I would do is replace the old tunnel fuel lines with SS, and check the rubber lines while you're at it.
cpavlenko
post Jun 23 2015, 01:02 PM
Rubber fuel line hose through the whole car was completed, less than a year ago. I've heard u have to drop motor and what about the gas tank. The gas tank was pulled and checked and everything was surprisingly clean in tank and where it drops in. All the wires looked good and clean, replaced bottom tank seals also. I always keep a eye on the fuel hose.
Cevan
post Jun 23 2015, 01:56 PM
I'd suggest using FI clamps instead of the ones you're using as they typically have a rounded edge are less likely to cut into the rubber fuel line.
914Mels
post Jun 23 2015, 02:05 PM
Stupid question, but what purpose do the deflectors have? What years had them?
cpavlenko
post Jun 23 2015, 02:56 PM
well, it's 105 degrees out side, and I took the teener out for a 40 mile cruise. when I got back home and checked my oil temp dip stick, it was at 250 degrees. this is to hot, seemed to run cooler without the flaps? so what I'm going to do is remove them and take the same cruise tomorrow and see if there's a difference. also I'm going to put the right clamps on. I have some extras. Air cooled only did that, and I'm going to call bout that. the temp is going to be the same here tomorrow.
Chris914n6
post Jun 23 2015, 03:12 PM
Jackstands are my life.
QUOTE(Cevan @ Jun 23 2015, 12:56 PM) *
If they are cutting you over tightened, or the rubber hose ID is too big.
screenguy914
post Jun 23 2015, 04:28 PM
QUOTE(cpavlenko @ Jun 23 2015, 01:56 PM) *
Some would like to know the purpose of the plastic rail(s) under the engine. Me too.
As for overheating, I would say one big factor is the 105ºF ambient temps. Not sure about the equipment on your engine, but an external oil cooler might be in order if that's the typical operating condition where you live.
Sherwood
cpavlenko
post Jun 23 2015, 04:42 PM
stock 1971 1.7. no frills.
budk
post Jun 23 2015, 06:50 PM
Yes! It's a Bumblebee!
The plastic flaps or deflectors are to create a low pressure area under the engine which allows the engine cooling to work better, assuming all the engine tin is in place and the thermostat/flaps are working properly.
rudedude
post Jun 23 2015, 07:28 PM
Where did you find a set of new looking deflectors?
cpavlenko
post Jun 23 2015, 08:45 PM
QUOTE(budk @ Jun 23 2015, 05:50 PM) *
All the engine tin is in.
GaroldShaffer
post Jun 23 2015, 08:49 PM
You bought another 914?
QUOTE(cpavlenko @ Jun 23 2015, 09:45 PM) *
Got the deflector flaps from Garold Shaffer. I don't know if he has more.
(IMG:style_emoticons/default/bye1.gif) Not new, just cleaned up.
cpavlenko
post Jun 23 2015, 08:51 PM
QUOTE(rudedude @ Jun 23 2015, 06:28 PM) *
Got the deflector flaps from Garold Shaffer. Don't know if he has anymore.
cpavlenko
post Jun 23 2015, 08:57 PM
QUOTE(screenguy914 @ Jun 23 2015, 03:28 PM) *
Sherwood
yea, I'm thinking the same thing. But during the winter it gets cold in northern AZ.
also I was wrong on outside temperature, it was only 95 degrees.
cpavlenko
post Jun 23 2015, 09:27 PM
QUOTE(914Mels @ Jun 23 2015, 01:05 PM) *
I believe 73 on, helps with cooling.
Eric_Shea
post Jun 24 2015, 08:09 AM
PMB Performance
Don't bother taking them off. That's not your problem. They do work and they work well.
I'm guessing your heater flapper bellows are not working properly. You may want to remove that and put it in boiling water to see how it responds. Also, make sure the cable is hooked up properly to the armature on the flappers.
rhodyguy
post Jun 24 2015, 08:21 AM
Just release the bellows control wire at the rod and make sure the vanes go to the open, default, position and see where the temps go on a same temp day. If the wire is too tight, or fastened with the vanes in the wrong position you won't get them to fully open.
SLITS
post Jun 24 2015, 08:49 AM
"This Utah shit is HARSH!"
Did you clean your on engine oil cooler?
While you really can't get it from the top, I use brake cleaner and spray up from the bottom. I then use compressed air to blow anything out of the fins, realizing that the foreign material is blown back on the cylinders.
Might be worth a try.
rhodyguy
post Jun 24 2015, 08:57 AM
Try ron's idea first.
- Lo-Fi Version Time is now: 12th March 2026 - 03:50 PM
