914-6 Shell Wanted to Restore, 914-6 Wanted |
bretth |
Jun 23 2015, 12:57 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Hello,
Looking for a 914-6 to save. No motor no problem. Rust? OK! Rolling? great. Basket cases considered. Please email if you have. (IMG:style_emoticons/default/welder.gif) Thank you for your time, Brett |
Cairo94507 |
Jun 23 2015, 02:00 PM
Michael Group: Members Posts: 9,826 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Hi Brett - There are a few of those shells floating around that need the skill of a welder and then some. Be patient, one will pop up on here that fits the bill. |
bretth |
Jun 23 2015, 08:19 PM
Great. Thanks Cairo!
Brett |
bretth |
Jul 23 2015, 12:07 PM
iwanta914-6 |
Jul 23 2015, 12:17 PM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
Did you try bidding on that one on Ebay that ended up over $30K? Good luck in your search! The search is probably the fun part since after you find one, it's all work after that, lol.
There is this one I keep seeing. It was posted on thesamba a couple months ago but it's still on their website... http://hymanltd.com/vehicles/5341-1971-porsche-914-6-targa/ |
bretth |
Jul 23 2015, 12:48 PM
I saw NY -6 on Ebay that ended the other day. Was only a hour away from me but price got up there quick. I already have a 911 motor that I want to use so I was hoping to get a roller needing a motor that I can put mine into. Almost bought a local 914-4 junker that had tons of rust when I got into "I gotta save them all mode". Later figured if I was willing to do the amount of fab and welding that this car needed I may as well wait and see if I can get a decent price on a real -6 that needed similar work.
I thought that 2nd car finally sold on Ebay a month or so back? Brett |
Nutter965 |
Jul 23 2015, 12:56 PM
Member Group: Members Posts: 139 Joined: 17-August 14 From: Uk Northern Ireland Member No.: 17,784 Region Association: None |
Is just me or does the hyman car look like a 4 ? Just the steering column is from a 4 and then there's the pic of the wiring loom with both Porsche stalks ... Maybe a numbers switch , only my thoughts ....
bretth |
Jul 23 2015, 01:15 PM
Is just me or does the hyman car look like a 4 ? Just the steering column is from a 4 and then there's the pic of the wiring loom with both Porsche stalks ... Maybe a numbers switch , only my thoughts .... Yeah sure is a giant hole where the dash mounted ignition is supposed to be. Hadn't noticed the column hole before you mentioned it. And no shots in the engine bay to see it there's a rain tray or -4 engine mounts. Has anyone seen any real attempts to fake a six with altered VIN tags and all? Brett |
iwanta914-6 |
Jul 23 2015, 01:21 PM
Has anyone seen any real attempts to fake a six with altered VIN tags and all? Brett With how cheaply you can aquire a 914 shell, it could be a possibility if sellers can turn a $2000 -4 shell into $15K+ profit by altering VIN tags. Something to look out for when you are searching anyway. |
gms |
Jul 23 2015, 04:52 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Is just me or does the hyman car look like a 4 ? Just the steering column is from a 4 and then there's the pic of the wiring loom with both Porsche stalks ... Maybe a numbers switch , only my thoughts .... I would not base my judgement about the authenticity of a car on an easily removed parts like a steering column unless it is a late model column. The late model steering column will not mount to a 914/6 bracket unless one or both of the parts are modified. If you are interested in the car you should check the VINs, Karmann Number and look for inconsistencies in the cars body...I.E. clipped sections. |
Meloosifah |
Jul 28 2015, 04:47 PM
I'm new here ... Group: Members Posts: 0 Joined: 4-July 15 From: Indiana Member No.: 18,915 Region Association: None |
The other thing to consider is the inconsistencies in the '71 -6's. There are several very late -6's that I am aware of that had transitional parts.
Lo-Fi Version | Time is now: 9th June 2024 - 01:52 PM |
