> phenolic spacers, for intake
jimkelly
post Jun 23 2015, 10:06 PM
Delaware USA
seems that intake gaskets already have the phenolic section included??
pic from ebay.
Replies(1 - 16)
Dave_Darling
post Jun 24 2015, 09:01 AM
914 Idiot
Yes, they do. I think there are also ones available without, though.
--DD
post Jun 24 2015, 12:24 PM
Resident German
QUOTE(Dave_Darling @ Jun 24 2015, 08:01 AM) *
You can also get the paper gaskets separately, but i highly recommend using the thicker phenolic spacers, even for carb conversions ...
BeatNavy
post Jun 24 2015, 01:28 PM
Ok, I'm going to ask a stupid question: I replaced my intake runner gaskets a while back with the Reinz product (I don't think the one pictured above). Was I supposed to use something else as well? I'm not familiar with phenolic gaskets. I have stock D-Jet...
dcecc1968
post Jun 24 2015, 02:52 PM
Thanks for posting this... I have a set of phenolic spacers to install on mine and was thinking that I needed to order gaskets for both sides, now I know better
-Don
Boxeer
post Jun 24 2015, 07:10 PM
Region Association: Middle East
Phenolic is harder than the gasket material. I recommend that you use 2 gasket on each side ;-)
Greg
jimkelly
post Jun 24 2015, 07:19 PM
Delaware USA
i think the above reinz ASSY pictured, is a phenolic spacer with a gasket on both sides.
so an order for 2ea assy should be all that is needed.
DBCooper
post Jun 24 2015, 07:21 PM
14's in the 13's with ATTITUDE
Just to clarify, with dual carbs, IDF's or DRLA's, use the phenolics because they'll keep the fuel in those carbs from heating up and even boiling. But with a center mounted carburetor you really DON'T want to use phenolic spacers. Reason is that with that long run from the carburetor to the head the runners tend to ice up in hot weather and fuel mixture will form droplets. Means it's a good thing to get some heat up into the runners, and no worry because the fuel in a center carb is too far away from the heads to ever get hot enough to boil the fuel in the bowl.
I know that may be a bit counter-intuitive, cool dual carbs, heat a single carb, but that's how it works.
jimkelly
post Jun 24 2015, 07:23 PM
Delaware USA
thanks DB : )
Elliot Cannon
post Jun 24 2015, 07:38 PM
Group: Retired Members
I have had dual 44idf's on my car for eleven years without the phenolic spacers and have never had an issue. (IMG:style_emoticons/default/biggrin.gif)
DBCooper
post Jun 24 2015, 07:48 PM
QUOTE(Elliot Cannon @ Jun 24 2015, 06:38 PM) *
Means you have a well-built engine so it ran cool. But get the timing off, mixture a bit lean, restrictive exhaust, cam not well matched to the heads/exhaust, etc, etc in the summer and you'll run it hot and cook your fuel. So good job on that engine. (eleven years... engines?). No big deal, most of us have a set or two in a box somewhere, so use them. Cheap insurance.
Dave_Darling
post Jun 24 2015, 09:58 PM
914 Idiot
QUOTE(DBCooper @ Jun 24 2015, 06:21 PM) *
... cool dual carbs, heat a single carb, but that's how it works.
Close, but not quite there. It's actually: Cool dual carbs, throw away single carbs.
--DD
DBCooper
post Jun 30 2015, 07:47 PM
QUOTE(Dave_Darling @ Jun 24 2015, 08:58 PM) *
--DD
You know Dave, I've repeated your "float test" for single carbs a number of times. Best explanation I've heard, so thanks. In this case it's temporary, so it's OK, but when he's done he can do the float test himself.
toadman
post Jul 1 2015, 07:11 AM
QUOTE(SirAndy @ Jun 24 2015, 10:24 AM) *
Who sells the paper gaskets separately?
stugray
post Jul 1 2015, 07:20 AM
QUOTE(toadman @ Jul 1 2015, 07:11 AM) *
I only used the paper gaskets when the spacers were new.
Now I just put a thin coat of RTV Blue on each side of the spacers.
Elliot Cannon
post Jul 1 2015, 04:07 PM
QUOTE(toadman @ Jul 1 2015, 06:11 AM) *
You might try here. http://www.cbperformance.com/SearchResults.asp?Cat=21
toadman
post Jul 1 2015, 04:55 PM
QUOTE(Elliot Cannon @ Jul 1 2015, 02:07 PM) *
They have them. Thanks for the tip!
- Lo-Fi Version Time is now: 1st July 2025 - 04:37 AM
