Rust Repair High on Fender/Cowl, Best reference or step-by-step threads? |
BeatNavy |
Jun 28 2015, 06:44 AM
Eventually I need to tackle this:
Underneath: I recall different threads in the past about how individuals tackled this (I think Palindrome thread removed the whole front fender), but I can't find them searching now. Anyone have a preferred thread for how best to scope and repair this little gem of a problem area? The more "See Spot run" it is the better... Danke... |
AndyB |
Jun 28 2015, 08:35 AM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
I saw CFR doing that repair. Be ready for more then one layer of metal. It's not overly hard just tedious.
0396 |
Jun 28 2015, 08:55 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Looks like the easiest is to remove and replace the fender.
rick 918-S |
Jun 28 2015, 09:09 AM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
This is similar to what you will need to do. This was crash damage but the same process for rust only in a more confined area.
http://www.914world.com/bbs2/index.php?sho...=177500&hl= |
mepstein |
Jun 28 2015, 09:12 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think it was tomeric (sp?) who did the repair on a silver 6 conversion. Did not remove the entire fender but cut away rusted portions. Scotty b has also done more than a few so he might have pics and advise. You can see what the metal looks like under the fender if you go to cairos build thread. Personally, I would not remove the entire fender to repair the cowl area.
sfrenck |
Jun 28 2015, 09:27 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
"Personally, I would not remove the entire fender to repair the cowl area" You'd just have Scotty do it... (IMG:style_emoticons/default/av-943.gif) |
mepstein |
Jun 28 2015, 09:35 AM
"Personally, I would not remove the entire fender to repair the cowl area" You'd just have Scotty do it... (IMG:style_emoticons/default/av-943.gif) I'd just put it aside and buy a couple more 914's. |
BeatNavy |
Jun 28 2015, 09:49 AM
"Personally, I would not remove the entire fender to repair the cowl area" You'd just have Scotty do it... (IMG:style_emoticons/default/av-943.gif) I'd just put it aside and buy a couple more 914's. Hey Mark - good plan! (IMG:style_emoticons/default/smile.gif) Writing a check is EASY! Good thing (for my wife) that my garage is maxed out already. I need to start throwing money at Scotty in Richmond. Having a solidly repaired 914 is probably a better investment than putting my daughter through school in Richmond... |
BeatNavy |
Jun 28 2015, 09:53 AM
This is similar to what you will need to do. This was crash damage but the same process for rust only in a more confined area. http://www.914world.com/bbs2/index.php?sho...=177500&hl= Thanks, Rick. I know there's no way I can approach your level of quality, but this helps. What kind of file do you use in that thread? I can't really see it in the pictures. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:20 PM |
