Optima Battery Question |
Ansbacher |
Jun 29 2015, 11:32 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
What is the latest proper fitting Optima Battery for a '74 2.0L ?? I am especially concerned about height restrictions, as my current conventional battery JUST clears the rain tray.
Ansbacher |
sportlicherFahrer |
Jun 29 2015, 12:32 PM
Nothing to see here. Group: Members Posts: 1,088 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Should be a group 42 IIRC. If you're going the optima route and are looking for a good solid way to mount it, Triad makes a killer mount plate for a good price. Not really any good pics on the site, but its a plate that bolts to the bottom of the battery using stainless hardware(included with the plate) in 4 spots. Then your regular battery hold-down bolt bolts the plate to the car's tray.
Triad West Performance |
GeorgeRud |
Jun 29 2015, 12:50 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I had a 43R in mine as the terminals were in the correct orientation for the car, but had to slice off the bottom mounting tabs on the sides to get it to fit correctly on the battery tray. Then I fabricated a wider battery mount to hold it down properly.
Check posts about Optima batteries - it seems that their quality has gone downhill. I had to replace one after just a few years, so now I stick with the easy to source Interstate bartteries and just keep the battery area clean, use dielectric grease on the fittings, and use a battery hat underneath to neutralize ant spilt battery acid. |
Johny Blackstain |
Jun 29 2015, 02:39 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I refuse to put a lead/acid battery in my LE ever again. The yellow Porsche acid pad that fits under the battery does not do a damned bit of good as far as I'm concerned. Optima 34R with the bottom tabs/ears sliced off the sides fits my 74 2.0 perfectly. I agree that Optima quality has gone downhill lately, however it's still cheaper than repairing rust caused by acid spill, acid boilover or rain/wash water mixed with battery acid.
Attached image(s) |
saigon71 |
Jun 29 2015, 02:42 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I went with the Optima 34 (not R). It puts the posts on the outboard side so they don't interfere with the stock rain tray. The rain tray hit the posts with the 34R.
It came with everything needed to mount in the stock location and fits well. I can't speak to the downturn in quality of these things...as this is my first one. |
Ansbacher |
Jun 29 2015, 07:40 PM
Responses very helpful and really appreciate the pics.l.
Ansbacher |
Big Len |
Jun 29 2015, 08:29 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
I went with the Optima 34 (not R). It puts the posts on the outboard side so they don't interfere with the stock rain tray. The rain tray hit the posts with the 34R. It came with everything needed to mount in the stock location and fits well. I can't speak to the downturn in quality of these things...as this is my first one. Have exactly the same setup. |
somd914 |
Jun 30 2015, 03:41 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Do yourself a favor and search the World for Optima issues and also Google it.
I'd either go for a Westco Miata battery or an Odyssey PC925. Plenty of mounting options and not difficult to fabricate your own. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:15 PM |
