Rust under battery tray, fixable? |
peter71 |
Feb 24 2005, 10:04 PM
Newbie Group: Members Posts: 18 Joined: 2-February 05 From: campbell,ca Member No.: 3,549 |
Hi, yet another question from a 914 rookie. I found a '73 2.0 that is in really good shape, except there is a patch of rust rot under the battery tray (around 3"x5")- a screwdriver could be easily pushed through. Is this a red flag, or is it a relatively easy (and hopefully inexpensive) fix? Where could i get this kind of work done and done well?
thanks for your help! |
redshift |
Feb 24 2005, 10:05 PM
I've never heard of that happening. It's unusual.
M |
SpecialK |
Feb 24 2005, 10:09 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
(IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
Allan |
Feb 24 2005, 10:13 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
It depends on how far it has spread. Just having a rotten spot under the battery tray is not too tough to fix but you need to find out how far into the hell hole it's gone and whether or not it has infested the suspension and long. Pics would be very helpful.
Miles I thought you were sick? |
skline |
Feb 24 2005, 10:14 PM
Cume on you guys, he is new, Yes it is fixable, no its not cheap, how much is the car? Or did you aleady buy it? The rust could be rally bad or it may just be minor rust. If it has gone through the longitudinal, I would pass on the car. If it has only rusted away the top layer of metal, it can be fixed. Look for sagging on the passenger side at the door jamb. Take pictures and post them here, we can tell better by looking at pictures. Look under the rocker panel on the passenger side. Look at the jack point also. See how bad the rust really is from the bottom. Its hard to say from your description.
Trekkor |
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
This will help you. (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
metal fabbers report KT |
peter71 |
Feb 24 2005, 10:27 PM
I haven't yet purchased the car, the seller is just being up front about the car. He just discovered this rust when installing the speedometer cable. He stated: a blotch about 3"x5". It is bad enough to
be able to poke through. The frame/floor, jackhole, rockers, suspension points all seem very solid. I haven't got any pics or the problem area, just the pics posted in the classifieds. thanks |
skline |
Feb 24 2005, 10:29 PM
Well, go look at the car, take pictures, poke around, ask someone from the club to go with you to look at it. You will be much better off.
redshift |
Feb 24 2005, 10:36 PM
Yes, as Scott says, it can be Rally bad, or just minor. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Gint is doing one that was Rally bad, use the search function for Rustoration and Gint M |
sgomes |
Feb 25 2005, 12:34 AM
Electric Member Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
I did a search on here for "rust". I got:
Fatal error: Maximum execution time of 30 seconds exceeded in D:\InetPub\www.914world.com\bbs2\sources\Search.php on line 1079 (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) I guess there was just too much. So I narrowed my search to "rust AND battery AND tray" I got 325 topics (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
sgomes |
Feb 25 2005, 12:37 AM
I just noticed you're in Campbell. There is about fifty people "in the club" that live around here. I'm sure one of us would be available for a PPI. I'd highly suggest taking it up to High Performance House if it's driveable.
peter71 |
Feb 26 2005, 09:00 AM
Here is a pic of the area. Its where the fuel pump used to rest (it has long since been relocated). Let me know what you think.
Attached image(s) |
914GT |
Feb 26 2005, 09:26 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Better throw several more 20s in there. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
skline |
Feb 26 2005, 08:53 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) Yeah, it will take more than a single 20 to fix it. However, it doesnt look that bad from underneath. That really isnt the area to check as that is not really structural. The place to look is under the battery tray on the inside of the engine compartment. Look for holes going into the Longitudinal. It can rust out on the outside of the long and still be an easy fix. If it rusts through the long, that is not such an easy fix but it is still fixable. As mentioned earlier, there are a lot of members up there that would be happy to go check it out with you. We also have morales so dont worry about someone taking the deal out from under you. They will simply be an outside source of information. How does the car run? Engines can get expensive to repair also. Do a leak down and compression check on the car, that will tell you a lot about the engine. If you have any more questions, post them here and send me a PM so I know its here. I have a lot to do over the next few weeks and may not check the threads as much as usual. |
skline |
Feb 26 2005, 09:38 PM
Here is a picture of the area in question, this is one of the most serious places to look for rust. This picture has repairable rust through that would be an easy fix in my opinion. Others may not want to tackle it but I would rather fix this than one that went through the long.
Attached image(s) |
Type 4 |
Feb 26 2005, 10:13 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Thats not Rust
This is Rust Attached image(s) |
Brando |
Feb 26 2005, 10:52 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) is about all i can say.
skline |
Feb 26 2005, 10:55 PM
Perfect example Steve, that rust is not something I would want to fix. Notice how the long itself is rusted through? That is when the car is beyond fixing in my opinion. |
Type 4 |
Feb 26 2005, 11:29 PM
That Copper Car really look nice didnt scott until I showed you that.
Attached image(s) |
redshift |
Feb 26 2005, 11:34 PM
HO GOD NO! AVERT MY EYES! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Ok Steve, one more assault like that, and you owe me a seeing eye dog. Is that what an HE round will do to a 914? -shiver- M |
Lo-Fi Version | Time is now: 1st June 2024 - 12:10 PM |
