solid core ignition wires or spiral, For my HYFIRE 6A |
Joe Ricard |
Feb 25 2005, 06:43 AM
So the directions say I should use the spiral wires. MSD makes a good low resistance set. But nowhere near the soild core stuff. I don't have any computer or radio so should I be worried about EMI interference maybe to the Mallory box itself?
machina |
Feb 25 2005, 06:55 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
The Mallory book says to NOT use solid core, so I didn't.
Trekkor |
Feb 25 2005, 07:02 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
MSD says the same thing. KT |
Joe Ricard |
Feb 25 2005, 07:36 AM
So I think MSD makes a big fatty wire that is carried through my favoritel FLAPS. It that what ya'll run?
machina |
Feb 25 2005, 07:46 AM
got magnecor 8.5's
Joe Ricard |
Feb 25 2005, 10:33 AM
Ok so time for a shameless plug. Where did you get Magnacor wires. Been looking this morning found more info than I can absorb but no place to buy 914-4 plug wires. Will I have to buy a set and modify? which will most likely degrade the EMI properties. Actually looking at the 8's because they are compatable with carbs and no electronics.
Rough_Rider |
Feb 25 2005, 10:47 AM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
I bought a magnecor set from ultrarev.com cheesy name & website. but there cheap!!!!
Regarding customisation for 914/4 give magnecor tech support a call / mail. There normally pretty good. http://www.magnecor.com/magnecor1/main.htm |
gklinger |
Feb 25 2005, 10:51 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
Here's one link:
Magnecor source When I bought my last set it was not from these guys, and I can't pull where out of my foggy memory. At the time I was able to spec a custom coil wire as I have a Crane coil with the male post at no extra charge. Also, be sure to use some dialectic grease on the boots. They're a tight fit and a real bitch to get off if you don't. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:09 PM |
