Oil Pressure Sending Hose Extension Kit |
mhenderson57 |
Jul 8 2015, 08:06 AM
Newbie Group: Members Posts: 9 Joined: 25-March 12 From: Georgia Member No.: 14,303 Region Association: South East States |
I'm looking for a braided stainless steel hose extension to install a oil pressure sending unit on my 2.0 liter engine. I would appreciate any advice on this purchase.
Thanks, Matt |
ChrisFoley |
Jul 8 2015, 08:11 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have several on the shelf.
stugray |
Jul 8 2015, 11:06 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I used a 10mmX1.0 to npt adapter and a grease gun hose extension from FLAPS but many just thread it right in to the case without the adapter.
DavidSweden |
Jul 8 2015, 11:14 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
stugray |
Jul 8 2015, 11:26 AM
Mark Henry |
Jul 8 2015, 12:30 PM
BTW if you use the grease gun hose you have to ground the sender unit.
ChrisFoley |
Jul 8 2015, 01:12 PM
IMO grease gun hoses don't last long in service.
pete000 |
Jul 8 2015, 02:14 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
The trick is how to install it with the engine in the car. I am still trying to figure out how to get a wrench down in there.
Anyone have any pictures of tools they have made or modified to tighten the hose fitting? |
Harpo |
Jul 8 2015, 04:13 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
pete000 |
Jul 8 2015, 04:23 PM
BeatNavy |
The trick is how to install it with the engine in the car. I am still trying to figure out how to get a wrench down in there. Anyone have any pictures of tools they have made or modified to tighten the hose fitting? Yeah, I did mine with the engine out of the car. Doing it with the engine in the car would seem to be a bit of a challenge. But I don't think you want to torque it too much. As Harpo suggested, I think a crows feet socket would be the best bet. I got mine at AA (I know, I know (IMG:style_emoticons/default/hide.gif) ). It wasn't a great value and I wish I had known Racer Chris had them. I would have gladly bought it from him instead. |
dangerranger01 |
Jul 8 2015, 05:02 PM
Member Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
I purchased everything from JEgs this is an Earls pre assembled AN-4 line. The first time I installed the grease gun line I used a 7/16 crows foot tool. When I install this new line I will only need a socket to install the 1/8 to AN-4 adapter What is that aluminum colored block in the center for? And is the stock thread 1/8npt? Do you all run the gauge full time? |
stugray |
If you use the adapter like in my pic above (brass piece), you can thread that in with a socket.
Then you can reach the hose fitting with an open end. |
mr914 |
Jul 8 2015, 05:17 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
If you have a Parker store nearby
It's Parker 919 hose. -4AN one side 1/4"FPT the other and a 1/4MPT to -4 male adaptor. 8"hose, or how long you like and they crimp it right there. Had on made at Christmas time in Rochester and the whole thing ran less than $20 Hose is tough stuff, rated for like 475F |
stugray |
Jul 8 2015, 06:04 PM
If you have a Parker store nearby It's Parker 919 hose. -4AN one side 1/4"FPT the other and a 1/4MPT to -4 male adaptor. 8"hose, or how long you like and they crimp it right there. Had on made at Christmas time in Rochester and the whole thing ran less than $20 Hose is tough stuff, rated for like 475F The thread in the case is very close to 1/8" NPT and a 1/8" NPT WILL thread in. However there is a huge debate about what the thread actually is. I am of the belief that it is 10mm x 1.0. The 10mm x 1.0 to 1/8" NPT fit perfectly and then the 1/8 Grease hose threaded into that more than 3 threads. |
Mike Bellis |
Jul 8 2015, 06:57 PM
The thread pitch (thread spacing really) is the same but the 1/8"NPT is a tapered thread, the 10mm is not tapered.
The 1/8" NPT will thread in and work but is not correct for the metric thread. I do not know of anyone that had a leak or thread failure using the NPT thread. |
Jake Raby |
Jul 8 2015, 08:48 PM
All you need is the hose from a paintball gun. Its rated to 3,000 PSI and is a braided hose. They ground the sensor, too.
I have had one in service for a decade on my own car. I think it cost 6 bucks last time I bought one. |
stugray |
Jul 8 2015, 08:57 PM
From the other thread:
This is what I used ... Paintball hose $2.75 Your price may vary. http://www.discountpaintball.com/Stainless...nch_p_5726.html |
Dtjaden |
Jul 8 2015, 10:14 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
This is also what I am using. |
Valy |
Jul 8 2015, 11:49 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
This will set you up with the adapter from 10mm to NPT, hose and gauge. $25
http://www.harborfreight.com/engine-oil-pr...-kit-98949.html |
Lo-Fi Version | Time is now: 7th June 2024 - 07:55 PM |
