The bad with the good |
spare time toys |
Feb 25 2005, 04:45 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
We know I found the rear of the Banana has 5 lug hubs and Im swapping them over to the racer. Weeeellll as I am going to take the wheel off the left side one of those sporty aluminum lug nuts Porsche is so proud of twisted off (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Anyone have a good tip as to how to get my twisted nut off (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Root_Werks |
Feb 25 2005, 04:56 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
As in: Left the tappered accorn part still on the stud? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
scotty914 |
Feb 25 2005, 04:58 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
drill an 1/8 inch hole down throught the lug nut then put in all steel center punch in the hole and drive it in till the nut splits
spare time toys |
Feb 25 2005, 05:05 PM
Yep it snapped at the end of the nut. there is about a 16th of an inch then the taper but they put threads in that part also. |
Mueller |
Feb 25 2005, 05:12 PM
are you sure it broke and it's not a locking lug nut??
I had a set similar to this design at one time: (IMG:http://www.boothedesign.com/assets/wheelLock4_lg.jpg) |
spare time toys |
Feb 25 2005, 05:42 PM
No .... it snapped off. But I didnt snap this time. No, no yelling and cussing I just roll with the flow. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Attached image(s) |
seanery |
Feb 25 2005, 05:49 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
give it a good soaking of PB Blaster while you're trying to figure out what to do (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
redshift |
Feb 25 2005, 05:51 PM
xsboost90 |
Feb 25 2005, 05:57 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
duuuude. I just went through a similar experience w/ a locking lug when the shop decided to keep my lock for awhile. ONe destroyed wheel later, i found it was easier to drill out the stud then to try and snap that aluminum off. ITs a biatch. Drill the stud out and get it over with. Believe me! (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
ClayPerrine |
Feb 25 2005, 06:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I thought that the banana had adapters rather than real 5 lug hubs....
So the rear was converted but not the front? |
Mueller |
Feb 25 2005, 06:06 PM
time to get out the Dremel® and try to stay as close to the stud so as to prevent damage to the wheel.
I had to do that with a locking lug nut similar to the one I posted above. The remainder of the broken part was too deep to be able to get a good hit on it with a chisel. |
spare time toys |
Feb 25 2005, 09:02 PM
It supprized the heck out of me when I found thes. I would have bet it was adapters all around. Wouldnt it be funny if I ever get the front trunk open to find a 911 front end in there. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
spare time toys |
Feb 27 2005, 04:36 PM
Well I got the wheel off but F'd up the lug hole a little. It can be saved this rim had a bad spot of curb rash any way so Ill take it to the wheel repair joint to be fixed.
Lo-Fi Version | Time is now: 9th June 2024 - 06:40 PM |
