Um.....is this normal? |
Bagpype |
Jul 10 2015, 03:14 PM
Newbie Group: Members Posts: 46 Joined: 9-July 15 From: Atlanta, ga Member No.: 18,936 Region Association: None |
McMark |
Jul 10 2015, 03:25 PM
Factory.
Stock. |
McMark |
Jul 10 2015, 03:28 PM
wndsrfr |
Jul 10 2015, 03:30 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Cant be. I found this hole someone apparently cut on top of the transmission. I havent started or driven it yet. Is this hole detrimental? Do I need to seal it? This is the passenger side. For some reason the picture got turned to the left. It's not going to hurt anything...just vents air out from behind the clutch area...drive it like you stole it.... |
EdwardBlume |
Jul 10 2015, 03:35 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Your transmission is clean and holy!
Larmo63 |
Jul 10 2015, 03:37 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
You time the engine through that hole.
Duh. |
Bagpype |
Jul 10 2015, 03:45 PM
Im highly mechanically inclined and this is my first vintage, air cooled Porsche. Im glad you guys are knowledgeable and patient people. Thanks for all the help and the future idiotic questions youre likely to have to help me with. Thanks!!
stugray |
Jul 10 2015, 03:49 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE You time the engine through that hole. I believe he is yanking your chain. You dont time the engine through there. However there IS another hole where you can see the TDC mark on the flywheel just above that hole where the case meets the engine case (at 12 oclock) I believe that it's purpose is for a clutch inspection or measurement. Perhaps there is a way to measure how much clutch disk you have left through there. |
72wrxporsche914 |
Jul 10 2015, 03:53 PM
Member Group: Members Posts: 52 Joined: 3-May 15 From: Fresno ca Member No.: 18,697 Region Association: None |
That's normal that hole is part of the casting of the trans . It's open to the clutch side of the transmission which is not in oil. Drive that thing no worries.
brant |
Jul 10 2015, 04:01 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I believe part of its purpose is cooling / venting
Used to have 2 friends racing teeners with 2.2/6 motors that significantly opened that hole for cooling with Tilton multi-plate clutches. |
theleschyouknow |
Jul 10 2015, 04:02 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
I'm trying to get 40 years of dirt and grease cleaned off my trans now I found that hole too and was wondering about it
as far as that goes do I need to worry about getting excess dirt and/or cleaning solution in there? (Dollar Store Awesome Cleaner) thanks cjl |
whitetwinturbo |
Jul 10 2015, 04:03 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
These have been known to hide there (IMG:style_emoticons/default/alien_2.gif)
TheCabinetmaker |
Jul 10 2015, 04:20 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm trying to get 40 years of dirt and grease cleaned off my trans now I found hole too and was wondering about it as far as that goes do I need to worry about getting excess dirt and/or cleaning solution in there? (Dollar Store Awesome Cleaner) thanks cjl You probably don't want to spray cleaner in there if the trans is installed on the engine. The clutch might not react well. |
shoguneagle |
Jul 10 2015, 04:22 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Always something new and interesting to learn on these cars. Such a joyful hobby!
theleschyouknow |
Jul 10 2015, 10:11 PM
I'm trying to get 40 years of dirt and grease cleaned off my trans now I found hole too and was wondering about it as far as that goes do I need to worry about getting excess dirt and/or cleaning solution in there? (Dollar Store Awesome Cleaner) thanks cjl You probably don't want to spray cleaner in there if the trans is installed on the engine. The clutch might not react well. more worried about the crud that might fall in there as I clean seems like that hole is basically wide open from the top(Gravity is not your friend in this case) surrounded by a nice flat spot that has collected a lot of dirt & grime just waiting to be busted loose and fall in that hole stuff a rag or some kinda plug in there? sorry for the hijack |
ndfrigi |
Jul 11 2015, 12:20 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
stugray |
Jul 11 2015, 12:26 AM
That is why I thought it might be an inspection hole.
You can see/touch the throwout bearing If you put a depth gauge in there when you installed a new clutch to get a baseline, I bet you could tell how much clutch plate you have left as it wore. (IMG:style_emoticons/default/confused24.gif) |
EdwardBlume |
Jul 11 2015, 06:32 AM
What pretty pictures.
I would say its a vent not a view hole since it doesn't have a cover. Germans are known for their detail. If it was an American car from the 70s, it could be a lift hole for the manufacturing process. Likely a vent. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:35 PM |
