> Help with rocker pannel screws
Harpo
post Jul 11 2015, 05:52 AM
My car is at paint and I would like to replace all of the rocker panel hardware. Does anyone have a source?
Replies(1 - 15)
EdwardBlume
post Jul 11 2015, 06:11 AM
I use standard metric bolts, washers, etc from my local hardware store. The last car I bought included a Pelican bolt kit, but Porsche used standard metric sizes for the most part...
Mikey914
post Jul 11 2015, 09:14 AM
The rubber man
Let me know what you find and I'll start stocking these along with the spacers.
I believe they are a hex head on the ends quite small not threaded like a bolt more like a screw
the bottoms are M6 bolts (12mm?).
Hope this helps. I do have the pop rivets cheap.
Harpo
post Jul 11 2015, 09:55 AM
I found two speed nuts on the top side of my rocker panels, one on each end. The other four holes on the top had nothing. I presume that they fell off. I checked bell metric but they don't have anything this small
https://www.belmetric.com/metric-screws-met...s-c-10_126.html
I will check with my fastener suppliers @ work on Monday
Mark yes it looks like the top screw is M4.2 and the bottom screw is M6 but I don't believe the M6 is a machine screw
DAvid
TheCabinetmaker
post Jul 11 2015, 09:59 AM
I drive my car everyday
Bottom screw's were the same as the engine tin screw's.
JawjaPorsche
post Jul 11 2015, 10:01 AM
Got stainless bolts with Phillips head from Home Depot. Take old ones to match up length and metric size.
Instead of rivets, I used stainless screws.
The link below has special spacers.
http://www.914centralshop.com/Porsche-914-...-rubbersill.htm
Tom_T
post Jul 11 2015, 10:11 AM
TMI....
#16 is a slotted cheese head metric, not hex Mark/Mikey914, & not Phillis Mark.
Phillips will cam-out before you get enough TQ on them to keep them in place.
Germans apparently transliterated that to "pan head" - which I associate with a low rounded shape like the inside of a frying pan - but the originals on mine were cheese head, which are flat around the edge circumference & about 1/16 - 3/32" tall (as shown in the diagram if you zoom in) - & those give a bit more "meat" than a pan head for the screwdriver to bite into while torquing down or loosening them.
Also, #13 is a black nylon/sim. spacer-washer about +/- 3/32" thick, which are harder to find than white ones (I just looked for similar ones in white for my Westy table locking bolts, but saw no black).
I think the AA & maybe A&P Girl (Mark's link above) & maybe others carry a "kit" for this hardware. I got the AA kit a while back to make it easier for me.
If you want to do the hunting yourself & aren't particular about being a bit off of originality (e.g.: hex instead of cheese head screws, etc.), then you can run the parts down using the PET descriptions at any old school hardware store(s) &/or online supplier(s) that stocks metric in a wide variety, but it will probably take you more than one source.
Sometimes it's just more cost & time effective to let someone else who's done all the sourcing on a wholesale basis to sell you a kit for a bit more than you might pay for the parts yourself + hours of running them down yourself.
Cheers! (IMG:style_emoticons/default/beerchug.gif)
Tom
Mikey914
post Jul 11 2015, 10:19 AM
The rubber man
I do gave the Pan heads that I brought in for the sheet metal they are .10 a pop. What I'm proposing is to just add these to the hardware section so every time this comes up someone can just grab kit for just about the price of the hardware. I have a hard time spending $15 for $4 worth of hardware. It's one thing if you manufacture it and have a cost to make it. I get that, but when it's a matter of sourcing it. If yo all want to source it I'll stock it. At hardware store prices.
Harpo
post Jul 11 2015, 10:46 AM
The 4.2 screws (according to PET) are the same as #8. I was unable to find any speed nuts aka "U" nuts for the # 8 screws.
Are the M6 screws machine or space thread screws? Do they thread in to weld nuts?
David
zoomCat
post Aug 12 2024, 11:47 PM
QUOTE(Harpo @ Jul 11 2015, 07:52 AM) *
The three on the bottom are the cheese head screws also used for type four engine tins.
https://914rubber.com/cheese-head-screw-set-1
Any M6x15 should work, though.
dr914@autoatlanta.com
post Aug 13 2024, 08:33 AM
we sell a little kit with all of the correct pieces
QUOTE(Harpo @ Jul 11 2015, 04:52 AM) *
Root_Werks
post Aug 13 2024, 02:39 PM
Village Idiot
Thought they were 6x1.0 roughly 12mm long. I used regular bolts so I could use a 10mm socket. Chased the threads on the 914, put a little white lithium grease on the bolts, done. Works very well for me.
rgalla9146
post Aug 13 2024, 05:13 PM
This is the original hardware. Three sets per side.
"cheesehead" screw with thread cleaner tip.
serrated lock washer and small diameter flat washer.
bkrantz
post Aug 13 2024, 07:52 PM
Belmetric. Infinite choices of sizes, lengths, finishes, etc.
Mikey914
post Aug 16 2024, 02:16 AM
The rubber man
We also have the rubber "spacers" https://914rubber.com/spacer-for-rocker-panel-and-valance
Mikey914
post Aug 16 2024, 02:17 AM
The rubber man
Double post
- Lo-Fi Version Time is now: 18th March 2026 - 02:04 PM
